[GRASS-user] Importing Landsat images with different coordinates
Micha Silver
micha at arava.co.il
Mon May 24 15:46:53 EDT 2010
On 05/24/2010 06:26 PM, Jenny Turner wrote:
> Hi
> Following this topic I have tested this methodology by converting from
> UTM 29N to a specific local coordinate system (EPSG:3763) (available
> at PROJ4)
> gdalwarp -t_srs "EPSG:3763" band_landsat.TIF destination.tif
> With that I got a segmentation error, one TIFFReadDirectory a lot of
> TIFFWriteEncodedStrip and the destination.tif has a different size.
Can you send the output of: gdalinfo band_landsat.TIF
> Any tips of what migh be wrong?
> Thank you
> Jenny
> On Tue, May 18, 2010 at 8:42 PM, Micha Silver <micha at arava.co.il
> <mailto:micha at arava.co.il>> wrote:
> Jenny Turner wrote:
> Greetings
> Firman, but imagine that I have rasters in UTM for differente
> zones (e.g. huge countries like USA, etc). How can I produce
> an automatic importing tool that uses gdalwarp to project an
> image to WGS84 and import to GRASS?
> Using gdalwarp you don't have to specify the source coordinate
> system, *if* the originals have the correct projection defined in
> their headers. For Landsat images, this is most likely the case,
> so you should be able to get away with just setting the -t_srs
> option of gdalwarp and each tile will be re-projected to the WGS84
> geographic CRS.
> Thanks for your help
> Best regards,
> Jenny
> On Mon, May 17, 2010 at 11:10 PM, Firman Hadi
> <jalmiburung at gmail.com <mailto:jalmiburung at gmail.com>
> <mailto:jalmiburung at gmail.com <mailto:jalmiburung at gmail.com>>>
> wrote:
> Hi,
> As far as I know you must define the source coordinate system.
> I think it is pretty straightforward when you are using
> gdalwarp.
> If there are so many images, maybe you can create a shell
> script
> to run the process.
> Cheers,
> Firman Hadi
> Center for Remote Sensing - ITB
> Jl. Ganesha No. 10,
> Labtek IX-C, 3rd Floor
> Bandung - 40132
> INDONESIA
> Phone: +62-22-2530701
> Fax: +62-22-2530702
> Website : http://crs.itb.ac.id ; www.sigro.org
> <http://www.sigro.org> <http://www.sigro.org>
> Blog : http://jalmiburung.wordpress.com
> JepratJepret: http://jalmiburung.fotografer.net
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Arava Development Co. +972-52-3665918
> http://www.surfaces.co.il
Micha Silver
http://surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100524/1f1d4c2f/attachment-0001.html
