[GRASS-user] Setting GRASS environment variable in a C program - step two
Wed May 26 11:12:36 EDT 2010
rabotin wrote:
> After that , using db_open_database(driver,&handle) command launch a
> segmentation fault. Is it because my handle is a null value ?
Possibly; change:
> 	std::cout << &driver << std::endl;
to:
> 	std::cout << driver << std::endl;
to confirm this.
> Are some commands missing to access or start dbf driver in my script ?
I can't see anything wrong, other than failing to check the return
value from db_start_driver().
