[GRASS-user] Setting GRASS environment variable in a C program
- step two
rabotin
rabotin at supagro.inra.fr
Wed May 26 11:30:53 EDT 2010
Thanks for helping me,
as you wrote I change
> std::cout << &driver << std::endl;
to:
> std::cout << driver << std::endl;
And I got a zero value return . So my driver isn't set ?
Is the problem from the following lines :
setenv("DBF_DRIVER","dbf",1);
setenv("DB_DATABASE","$GISDBASE/$LOCATION_NAME/$MAPSET/dbf",1);
I didn't write but I use grass 6.4 on ubuntu 9.10.
Do you know other commands to test or to set the dbf driver than
db_start_driver command ?
Cheers
Mick
Glynn Clements a écrit :
> rabotin wrote:
>> After that , using db_open_database(driver,&handle) command launch a
>> segmentation fault. Is it because my handle is a null value ?
> Possibly; change:
> to:
> to confirm this.
>> Are some commands missing to access or start dbf driver in my script ?
> I can't see anything wrong, other than failing to check the return
> value from db_start_driver().
Michaël Rabotin
Ingénieur d'étude en géomatique
Laboratoire d'étude des Interactions Sol, Agrosystème et Hydrosystème
UMR LISAH SupAgro-INRA-IRD
Bat. 24
2 place Viala
34060 Montpellier cedex 1
FRANCE
Téléphone : 33 (0)4 99 61 23 85
Secrétariat : 33 (0)4 99 61 22 61
Fax : 33 (0)4 67 63 26 14
E-mail : rabotin at supagro.inra.fr
