[GRASS-user] Re: Trying python scripts.
Marcello Gorini
gorini at gmail.com
Thu May 27 18:07:11 EDT 2010
Marcello Gorini wrote:
> >>> ... I am trying to run the first examples found in
> >>> http://grass.osgeo.org/wiki/GRASS_and_Python.
a script was here - look first post !
> >>> It seems to run OK and “100%” is displayed in the GRASS prompt, but
> >>> when I tried to display the map, I found out that it wasn't created at
> >>> all.
Nikos Alexandris:
> >> If there are no errors and the script ran fine, maybe you just need to
> >> check the region settings?
> >>> Just for you to know, to run the script I simply create it (say
> >>> "myscript.py"), give permissions and run it in a GRASS session with
> the
> >>> necessary options:
> >>> > ./myscript.py output=outmap raster1=map1 raster2=map2
> >>> I am using Ubuntu 9.04 64bits and GRASS 6.4.ORC5.
> >> For example:
> >> # check region extent, etc.
> >> g.region -p
> >> # set region extent and resolution to the map of your interest
> >> g.region rast=outmap -pa
> >> # give color
> >> r.colors rast=outmap color=rainbow
> >> # try to display
> >> d.mon x0 && d.rast outmap
> >> # is it there?
Marcello Gorini:
> >> No, it is not there. To make sure I set the region to the input map:
> >> g.region rast=map1 -pa
> >> d.mon x0 && d.rast map1
> >> OK, it is there. Then I ran the script:
> >> After processing, I tried:
> >> d.rast outmap
> >> But then:
> >> ERROR: Raster map <outmap> not found
> >> What could be wrong?
Nikos Alexandris:
>>Marcello, not sure why it does not work for you. I (copied over the script
>>from the 1st post in this thread as test_mapcalc.py, added +x to make it
>>executable) and it works fine for me:
>># test run
>>python test_mapcalc.py raster1=mod_b2 raster2=mod_b2_new
>>output=testing_mapcalc_python_script
>># r.info on inputs and the output
>># mod_b2
>>r.info -r mod_b2
>>min=0
>>max=5504
>># mod_b2_new
>>r.info -r mod_b2_new
>>min=0
>>max=0.5504
>># output
>>r.info -r testing_mapcalc_python_script
>>min=0
>>max=5504.5504
> >> P.S.: By the way, is this the right way to quote answers?
>>Like (almost) always, it depends whom you are asking ;-). There are so
many
>>ways and opinions and habits and... (you can scan the archive or other
mailing
>>lists and you'll find that people even argue seriously about the "correct"
way
>>to reply).
>>Personally I got stuck with _clean_ in-line bottom posting because I find
it.
>>so useful when I read older threads and understand what has been discussed
and
>>get to the point right away.
>>I prefer to invest time and clean-out un-necessary stuff (taking though
>>sometimes the risk to reject parts that are important?) and give a logical
>>flow to the discussion (first the question, then the answer) in order to
make
>>it easier for any (next) reader.
>>Regards, Nikos
Hello Nikos,
Thanks for the try. I tested it again with other rasters, but I got the same
error.
Could it possibly be something related to the 64bits architecture? Or could
GRASS be sending the outcome somewhere else?
Well, I guess that eventually I will go around this problem or even bump
into the solution, but the most important thing to say is that I appreciated
the effort and that it was a very good reception to this list.
Thank you very much Nikos. And thank you also for the explanations with
respect to the right way to answer posts. I will do my best to make my posts
as clean and explanatory as possible.
Best regards,
Marcello.
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5110760.html
Sent from the Grass - Users mailing list archive at Nabble.com.
