[GRASS-user] Setting GRASS environment variable in a C program - step two
rabotin rabotin at supagro.inra.fr
Fri May 28 03:46:16 EDT 2010
It finally works !
For information, the issue was here
setenv("GISBASE","/usr/lib/grass64/dist.i486-pc-linux-gnu",0);
I replace by this following line
setenv("GISBASE","/usr/lib/grass64/",0);
and it works
Thanks again for your help Glynn
Michael Rabotin
Glynn Clements a écrit :
> rabotin wrote:
>> If (inside a GRASS session), I access with  v.db.connect -p map=GU0507
>> it looks ok :
>> Vector map <GU0507 at simon9> is connected by:
>> layer <1> table <GU0507> in database
>> </home/rabotin/grassdata/Roujan/simon9/dbf/> through driver <dbf> with
>> key <cat>
>> Do you know how to launch a grass command (e.g. v.db.connect) inside a C
>> script
>> I try this line in my C progam
>> system(v.db.connect -p map=GU0507)
>> but I have an error message
>> sh: v.db.connect: not found
> That indicates the $GISBASE/bin isn't in $PATH.
> For a list of envionment variables which may be useful, I suggest
> reading this:
> http://grass.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
Michaël Rabotin
Ingénieur d'étude en géomatique
Laboratoire d'étude des Interactions Sol, Agrosystème et Hydrosystème
UMR LISAH SupAgro-INRA-IRD
Bat. 24
2 place Viala
34060 Montpellier cedex 1
FRANCE
Téléphone :  33 (0)4 99 61 23 85
Secrétariat : 33 (0)4 99 61 22 61
Fax : 33 (0)4 67 63 26 14
E-mail : rabotin at supagro.inra.fr
