[GRASS-user] Re: Trying python scripts.
Marcello Gorini
gorini at gmail.com
Fri May 28 07:23:58 EDT 2010
Nikos Alexandris wrote:
> Marcello Gorini wrote:
>> Thanks for the try. I tested it again with other rasters, but I got the
>> same error. Could it possibly be something related to the 64bits
>> architecture?
> I don't think so. I work with Kubuntu Lucid 64 bit :-)
>> Or could GRASS be sending the outcome somewhere else?
> Negative. You are running the script from within a grass-session (as you
> wrote
> in the first post). Let's try to take this step by step. What is the
> result of
> each of the following commands:
> ls -l myscript.py
> g.gisenv
> g.region -p
> r.info map1
> r.info map2
>> Well, I guess that eventually I will go around this problem or even bump
>> into the solution, but the most important thing to say is that I
>> appreciated the effort and that it was a very good reception to this
>> list.
> Bah... it was only me trying to not forget the basics with python scripts.
> You will get better and more precise replies from other advanced users and
> developers.
>> Thank you very much Nikos. And thank you also for the explanations with
>> respect to the right way to answer posts. I will do my best to make my
>> posts as clean and explanatory as possible.
> You are warned, you might get yourself into trouble ;-p
> Cheers, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
OK, thank you, so let's go step by step:
ls -l myscript.py
result:
-rwxr-xr-x 1 marcello marcello 1227 2010-05-28 08:13 myscript.py
g.gisenv
result:
GISDBASE=/home/marcello/grassdata
LOCATION_NAME=Ocean_floor
MAPSET=level4
MONITOR=x0
GRASS_GUI=tcltk
g.region -p
result:
projection: 99 (Mercator)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 3947900
south: 3633400
west: -7366700
east: -7022600
nsres: 3700
ewres: 3700
rows: 85
cols: 93
cells: 7905
r.info map1
result:
| Layer: map1 Date: Thu May 27 18:48:30 2010
| Mapset: level4 Login of Creator: marcello
| DataBase: /home/marcello/grassdata
| Title: ( topmod )
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 1177
| Columns: 1388
| Total Cells: 1633676
| Projection: Mercator
| N: 6358450 S: 2003550 Res: 3700
| E: -3920150 W: -9055750 Res: 3700
| Range of data: min = 0.000000 max = 10000.000000
| Data Description:
| generated by r.mapcalc
| Comments:
| if(topmod > 0, 0, -topmod)
r.info map2
result:
| Layer: map2 Date: Thu May 27 18:49:29 2010
| Title: ( topmod2 )
| Timestamp: none
| Data Type: FCELL
| Rows: 1177
| Columns: 1388
| Range of data: min = 1000.000000 max = 1000.000000
| Data Description:
| Comments:
| if(topmod > -2, 1000, topmod)
Now just to emphasize :)
Result of "r.info outmap":
ERROR: Raster map <outmap> not found
Can you make anything out of it?
Best regards,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5112658.html
Sent from the Grass - Users mailing list archive at Nabble.com.
