[GRASS-user] DAtum Warning while using r.in.gdal
Kim Besson kimbesson1981 at gmail.com
Mon May 31 12:25:33 EDT 2010
Greetings
Following a few suggestions made at this list I'm using gdalwarp to project
a few landsat images and only then yusing r.in.gdal.
I'm using this expression to reproject image:
gdalwarp -t_srs "+proj=tmerc +lat_0=39.66825833333333
+lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +units=m +no_defs
" L71203033_03320001023_B10.TIF  landsat_out.tif
And when I run r.in.gdal I get this warning:
Datum <unknown> not recognised by GRASS and no parameters found
Projection of input dataset and current location appear to match
What does this means?
Thanks
kim
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100531/11340bbf/attachment.html
