[GRASS-user] d.rast.arrows in high quality plot
Nicolas Pérenne
nicolas.perenne at free.fr
Tue Nov 2 18:26:01 EDT 2010
Hi Niklas,
Same for me: the PNG driver draws thinner and thinner arrows when you
increase the resolution. If you lower the resolution it's okay though.
If you do need such a high resolution (for a poster?), you might try the
CAIRO driver (g.manual displaydrivers) which behaves quite differently
when producing PNGs. Arrows are drawn with a thicker pen indeed (even at
high pixel resolution) but you might be surprised by the raster
rendering... and files get very large.
Nicolas
Le mardi 02 novembre 2010 à 16:12 +0100, Niklas Neckel a écrit :
> Dear all,
> I'm trying to plot arrows, representing length proportional to magnitude in a printable high resolution map (with d.rast.arrows). Here is what I tried:
> #!/bin/sh
> export GRASS_WIDTH=10000
> export GRASS_HEIGHT=10000
> export GRASS_PNG_COMPRESSION=0
> #export GRASS_RENDER_IMMEDIATE=TRUE
> export GRASS_TRUECOLOR=TRUE
> g.region fig_arrows
> d.mon start=PNG
> d.rast map=background at PERMANENT
> d.rast map=Magnitude_map at PERMANENT
> d.rast.arrow map=Direction_map at PERMANENT type=compass arrow_color=black grid_color=none x_color=black unknown_color=red skip=12 scale=20 magnitude_map=Magnitude_map at PERMANENT
> d.mon stop=PNG
> eog $GRASS_PNGFILE&
> Unfortunately the plotted arrows are quite slim now... is there another solution to achieve this goal?
> Many thanks,
> Niklas
