[GRASS-user] d.rast.arrows in high quality plot
Niklas Neckel
Nikneck at gmx.de
Wed Nov 3 04:16:34 EDT 2010
Hi Nicolas,
Thank you very much! The arrows are thicker now and are visible on the final plot.
Cheers,
Niklas
-------- Original-Nachricht --------
> Datum: Tue, 02 Nov 2010 23:26:01 +0100
> Von: "Nicolas Pérenne" <nicolas.perenne at free.fr>
> An: Niklas Neckel <Nikneck at gmx.de>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] d.rast.arrows in high quality plot
> Hi Niklas,
> Same for me: the PNG driver draws thinner and thinner arrows when you
> increase the resolution. If you lower the resolution it's okay though.
> If you do need such a high resolution (for a poster?), you might try the
> CAIRO driver (g.manual displaydrivers) which behaves quite differently
> when producing PNGs. Arrows are drawn with a thicker pen indeed (even at
> high pixel resolution) but you might be surprised by the raster
> rendering... and files get very large.
> Nicolas
> Le mardi 02 novembre 2010 à 16:12 +0100, Niklas Neckel a écrit :
> > Dear all,
> > I'm trying to plot arrows, representing length proportional to magnitude
> in a printable high resolution map (with d.rast.arrows). Here is what I
> tried:
> > #!/bin/sh
> > export GRASS_WIDTH=10000
> > export GRASS_HEIGHT=10000
> > export GRASS_PNG_COMPRESSION=0
> > #export GRASS_RENDER_IMMEDIATE=TRUE
> > export GRASS_TRUECOLOR=TRUE
> > g.region fig_arrows
> > d.mon start=PNG
> > d.rast map=background at PERMANENT
> > d.rast map=Magnitude_map at PERMANENT
> > d.rast.arrow map=Direction_map at PERMANENT type=compass arrow_color=black
> grid_color=none x_color=black unknown_color=red skip=12 scale=20
> magnitude_map=Magnitude_map at PERMANENT
> > d.mon stop=PNG
> > eog $GRASS_PNGFILE&
> > Unfortunately the plotted arrows are quite slim now... is there another
> solution to achieve this goal?
> > Many thanks,
> > Niklas
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
GRATIS! Movie-FLAT mit über 300 Videos.
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome
