[GRASS-user] r.thin ?
charlie
carowan at yahoo.com
Tue Nov 9 00:25:03 EST 2010
Hi. I am currently using Grass 6.4 on linux and beginning the the process of vectorizing an old NOAA raster map with r.thin. The map is approximately 12,000 pixels by 8,000 pixels wide.
According to this post, ( http://osgeo-org.1803224.n2.nabble.com/r-thin-td2718260.html#a2718260 )the iteration variable has to be equal or larger than half the number of cells of the wider line so I increased the iterations to 6,000, and it would up finishing in approximately 4,200 passes.
Previously, I was getting excellent preliminary results, with fewer (1,000) iterations, distinct features were visible, however at least 50% of the map was not completed.
Now with an increase to 6,000 iterations r.thin completes, but the results are a single 1px wide horizontal line. Im sure I am overlooking something relatively simple; can anyone give me any advice on how to best run r.thin in this particular case?
Thanks!
Charlie
<a href="www.wetlandresearch.com">Wetlands</a>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101108/e00920a7/attachment.html
