[GRASS-user] r.thin ?
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Tue Nov 9 05:20:53 EST 2010
how do you use r.thin? Can you post the complete command?
Am 09.11.2010 06:25, schrieb charlie:
> Hi. I am currently using Grass 6.4 on linux and beginning the the
> process of vectorizing an old NOAA raster map with r.thin. The map is
> approximately 12,000 pixels by 8,000 pixels wide.
> According to this post, (
> http://osgeo-org.1803224.n2.nabble.com/r-thin-td2718260.html#a2718260
> )the iteration variable has to be equal or larger than half the number
> of cells of the wider line so I increased the iterations to 6,000, and
> it would up finishing in approximately 4,200 passes.
> Previously, I was getting excellent preliminary results, with fewer
> (1,000) iterations, distinct features were visible, however at least 50%
> of the map was not completed.
> Now with an increase to 6,000 iterations r.thin completes, but the
> results are a single 1px wide horizontal line. Im sure I am overlooking
> something relatively simple; can anyone give me any advice on how to
> best run r.thin in this particular case?
> Thanks!
> Charlie
> <a href="www.wetlandresearch.com">Wetlands</a>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
