[GRASS-user] r.thin ?
Micha Silver micha at arava.co.il
Tue Nov 9 05:24:33 EST 2010
charlie wrote:
> Hi.  I am currently using Grass 6.4 on linux and beginning the the
> process of vectorizing an old NOAA raster map with r.thin. The map is
> approximately 12,000 pixels by 8,000 pixels wide.
> According to this post, (
> http://osgeo-org.1803224.n2.nabble.com/r-thin-td2718260.html#a2718260
> )the iteration variable has to be equal or larger than half the number
> of cells of the wider line so I increased the iterations to 6,000, and
> it would up finishing in approximately 4,200 passes.
> Previously, I was getting excellent preliminary results, with fewer
> (1,000) iterations,  distinct features were visible, however at least
> 50% of the map was not completed.
> Now with an increase to 6,000 iterations r.thin completes, but the
> results are a single 1px wide horizontal line.  Im sure I am
> overlooking something relatively simple; can anyone give me any advice
> on how to best run r.thin in this particular case?
What is it you are trying to do? The r.thin module is designed to make
line features in a raster exactly one pixel wide so that when converting
to a line vector, the line will be clean.
If you run r.thin on a raster that represents areas, and give a high
enough iteration value, the areas will eventually be reduced to lines.
> Thanks!
> Charlie
> <a href="www.wetlandresearch.com">Wetlands</a>
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
