[GRASS-user] Using v.colors in WinGRASS
Luisa Peña luisapena1979 at gmail.com
Tue Nov 9 06:55:26 EST 2010
Greetings
I'm using winGRASS6.4.1 (compiled from OSGEO4w) and I'm having a difficulty
on applying v.colors.
I have a raster map (r.reclass) that I convert to vector/areas. So far so
good...
But when I try to apply v.colors with this expression:
v.colors map=teste01_LULC at Regional column=cat color=aspect
I get this error:
Creating column <GRASSRGB> ...
E:/GRASS6/scripts/v.colors: v.db.addcol: command not found
ERROR: Creating color column
This v.db.addcol is present in the Scripts folder
If i do v.info to my vector file I get this information...
 | Layer:           teste01_LULC
 | Mapset:          Regional
 | Location:        LOCAL                                                |
 | Database:        E:\v3
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: orbit                                              |
 | Organization:
 | Source date:     Tue Nov 09 11:11:40 2010
 |   Type of Map:  vector (level: 2)
 |   Number of points:       0               Number of areas:      213680
 |   Number of lines:        0               Number of islands:    73649
 |   Number of boundaries:   348770          Number of faces:      0
 |   Number of centroids:    213666          Number of kernels:    0
 |   Map is 3D:              No
 |   Number of dblinks:      1
 |         Projection: Universal Transverse Mercator (zone 0)
 |               N:  8832707.83027649    S:  7028073.62772369
 |               E:  1347458.42001915    W:    200792.5777576
 |   Digitization threshold: 0
 |   Comments:
Can anybody help me?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101109/dd1203b8/attachment-0001.html
