[GRASS-user] Using v.colors in WinGRASS
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Tue Nov 9 07:08:56 EST 2010
v.db.addcol should be there by default.
Maybe there has to be a table connected to the vector map!
This can bo done with 'v.db.addtable'.
Achim
Am 09.11.2010 12:55, schrieb Luisa Peña:
> v.colors map=teste01_LULC at Regional column=cat color=aspect
> I get this error:
> Creating column <GRASSRGB> ...
> E:/GRASS6/scripts/v.colors: v.db.addcol: command not found
> ERROR: Creating color column
> This v.db.addcol is present in the Scripts folder
