[GRASS-user] Re:Using v.colors in WinGRASS
Micha Silver
micha at arava.co.il
Tue Nov 9 08:05:26 EST 2010
Achim Kisseler wrote:
> vector-map - layers - categories - database-connection: thats a bit
> confusing, but manageble:
> Am 09.11.2010 13:27, schrieb Luisa Peña:
>> 1- How can I know that this particular vector data does/doesn't have
>> a table?
> v.db.connect -p map=your_map
>> 2- Since this is a vector, created from a raster (r.to.vect) can I
>> add a table when I create the vector?
> No, thats what I dont like, too
>> 3- How can I define a table in order to be used by v.colors?
> v.db.addtable
In addition, it might be a good idea, while you create the table, to add
the column for colors. the default column name is GRASSRGB and it should
be a text column (format the RGB colors as RRR:GGG:BBB in that column)
So
v.db.addtable <vector map> column="GRASSRGB varchar(12)"
> I use sqlite as database, because it consists of only one file (so it
> is easy (for a single user)).
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
