[GRASS-user] raster data output
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Wed Nov 10 12:03:20 EST 2010
Did you see:
http://grass.fbk.eu/statsgrass/grass_geostats.html
Am 10.11.2010 16:23, schrieb Steve Wangen:
> Hello list -
> There may be a simple solution to my problem, but I'm a bit new to
> grass and haven't been able to track it down yet, so I was wondering
> if anyone had suggestions. I'm trying to output the cell contents of
> multiple rasters into a single table that I can save to a file with
> the desired result looking like this:
> x-coord     y-coord     raster1     raster2     raster3     ...
>      0              0              1             2            3         ...
>      0              1              0             1            2         ...
>      0              2              0             0            1         ...
> etc...
> with the idea of doing some time series analyses, where the subsequent
> rasters are different time steps. Ideally this would come out as one
> table that I could then import into R for analysis. I've had a bit of
> luck outputing the result of r.stats -x to a file using some bash
> scripting and then combining all those files manually, but it seems
> there would be an easier solution.
> Any suggestions would be appreciated.
> Thanks!
> -Steve
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
