[GRASS-user] Reclass: Atributte a string
    Franz Schiller
    franzschiller1975 at gmail.com
    Fri Nov 12 03:32:18 EST 2010
Hello Glynn
Thanks for the reply. About using r.categories, can I apply it to a raster
map and then export it as a "normal" raster?
Thanks
Franz
On Fri, Nov 12, 2010 at 6:18 AM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Franz Schiller wrote:
> > I'm doing a reclass of rasters based on a rule file. In this file I'm
> doing
> > a correspondence between values (1,2... 100) to other integer values.
> > Is it possible to do this but instead to done this to Numbers do this to
> > Strings just like
> > 1 = "Agriculture"
> > 2,3,4= "Forest"
> You can associate category labels with each category using
> r.categories. You can't "reclass" to a string.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101112/980c4663/attachment.html
