Franz Schiller wrote: > Thanks for the reply. About using r.categories, can I apply it to a raster > map and then export it as a "normal" raster? category labels are attached to an existing map; there's nothing to export. It might help if you explain what your ultimate goal is. -- Glynn Clements <glynn at gclements.plus.com>
