[GRASS-user] Re: Exporting Vector data to SHP (v.out.ogr)- takes a
lot of time
Luis Lisboa
luislisboa1975 at gmail.com
Fri Nov 12 03:40:24 EST 2010
The problem is that, I left it this night processing and, when I
returned it has freezed. So, v.out.ogr is not being able to export
vector files produced by r.to.vect... As I said, maybe it's related
with some option in r.to.vect that is messing this up. Or something
related with tables.
Can anyone give me some tips on this?
Thanks
Luis
>...that´ll be a HUGE vector file!
>So it´s normal, that it takes some minutes.
On Thu, Nov 11, 2010 at 3:08 PM, Luis Lisboa <luislisboa1975 at gmail.com>wrote:
> Greetings
> I have produced a vector map (with r.to.vector) with the following
> metadata:
> v.info test01
> | Layer: teste01 |
> | Mapset: Regional
> | Location: Country
> | Database: E:\v3
> | Title:
> | Map scale: 1:1
> | Map format: native
> | Name of creator: orbit |
> | Organization:
> | Source date: Tue Nov 09 11:11:40 2010
> | Type of Map: vector (level: 2)
> | Number of points: 0 Number of areas: 213680
> | Number of lines: 0 Number of islands: 73649
> | Number of boundaries: 348770 Number of faces: 0
> | Number of centroids: 213666 Number of kernels: 0
> | Map is 3D: No
> | Number of dblinks: 1
> | Projection: Universal Transverse Mercator (zone 0)
> | N: 8832707.83027649 S: 7028073.62772369
> | E: 1347458.42001915 W: 200792.5777576
> | Digitization threshold: 0
> | Comments:
> Now I'm trying to export it to SHAPEFILE but, after 10 minutes the
> processing bar is not even in 40%. What might be happening? I mean, is it
> some error with the vector or when I convert to vector (from raster)?
> Because, taking more than 10 minutes to export to vector it's not normal (I
> guess) and taking nearly 7 min to convert to vector also...
> Thanks for the reply
> Luis L
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101112/e8d5348f/attachment.html
