[GRASS-user] Re: Exporting Vector data to SHP (v.out.ogr)- takes
a lot of time
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri Nov 12 04:06:56 EST 2010
Am 12.11.2010 09:40, schrieb Luis Lisboa:
> The problem is that, I left it this night processing and, when I returned it has freezed. So, v.out.ogr is not being able to export vector files produced by r.to.vect... As I said, maybe it's related with some option in r.to.vect that is messing this up. Or something related with tables.
> Can anyone give me some tips on this?
I guess it freezes because it uses so much memory.
Please check if v.out.ogr works with a small vector map. E.g. shrink
region before r.to.vect or choose only some features from the vector map
to export.
Achim
> Thanks
> Luis
>>...that´ll be a HUGE vector file!
>>So it´s normal, that it takes some minutes.
> On Thu, Nov 11, 2010 at 3:08 PM, Luis Lisboa <luislisboa1975 at gmail.com
> <mailto:luislisboa1975 at gmail.com>> wrote:
> Greetings
> I have produced a vector map (with r.to.vector) with the following
> metadata:
> v.info <http://v.info> test01
> | Layer: teste01
> | Mapset: Regional
> | Location: Country
> | Database: E:\v3
> | Title:
> | Map scale: 1:1
> | Map format: native
> | Name of creator: orbit
> | Organization:
> | Source date: Tue Nov 09 11:11:40 2010
> | Type of Map: vector (level: 2)
> | Number of points: 0 Number of areas:
> 213680 |
> | Number of lines: 0 Number of islands:
> 73649 |
> | Number of boundaries: 348770 Number of faces:
> 0 |
> | Number of centroids: 213666 Number of kernels:
> 0 |
> | Map is 3D: No
> | Number of dblinks: 1
> | Projection: Universal Transverse Mercator (zone 0)
> | N: 8832707.83027649 S: 7028073.62772369
> | E: 1347458.42001915 W: 200792.5777576
> | Digitization threshold: 0
> | Comments:
> Now I'm trying to export it to SHAPEFILE but, after 10 minutes the
> processing bar is not even in 40%. What might be happening? I mean,
> is it some error with the vector or when I convert to vector (from
> raster)? Because, taking more than 10 minutes to export to vector
> it's not normal (I guess) and taking nearly 7 min to convert to
> vector also...
> Thanks for the reply
> Luis L
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
