[GRASS-user] Re:Using v.colors in WinGRASS
    Martin Landa
    landa.martin at gmail.com
    Mon Nov 15 05:12:20 EST 2010
2010/11/15 Luisa Peña <luisapena1979 at gmail.com>:
>> download manually Python scripts v.colors [1] and v.db.addcolumn [2]
>> and integrate them to your GRASS 6 installation. You have of course
>> more possibilities
> In This case, these are python scripts right? Ok I will give a try.
they should be OK, if not, it's *much more* easier to fix them.
>> 2) fix Bash scripts on Windows (keep in mind that these fixes will
>> disappear in GRASS7 because it uses Python)
> But, as far as I can see from this discussion, there is no FIX for this
Read as: you fix them or convince someone to do it.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
