[GRASS-user] Re:Using v.colors in WinGRASS
Luisa Peña luisapena1979 at gmail.com
Mon Nov 15 10:33:14 EST 2010
Hi
Ok here it goes.
1- I needed to remove .py from v.colors and v.db.addcolumn scripts in order
to run them in GRASS6.4.0.
2- v.info teste12
 |   Type of Map:  vector (level: 2)
 |   Number of points:       0               Number of areas:      87
 |   Number of lines:        0               Number of islands:    28
 |   Number of boundaries:   164             Number of faces:      0
 |   Number of centroids:    87              Number of kernels:    0
 |   Map is 3D:              No
 |   Number of dblinks:      1
 |         Projection: Universal Transverse Mercator (zone 0)
 |               N:    9332730.901707    S:    9315930.306024
 |               E:     657285.028897    W:     631785.609702
 |   Digitization threshold: 0
 |   Comments:
3- If I select an area I get this info:
East: 638957.32135
North: 9327883.257322
Map: teste12
Mapset: Regional
Type: Centroid
Layer: 1
Category: 2
Driver: dbf
Database: C:\ISdata/Brazil/Regional/dbf/
Table: teste12
Key column: cat
cat : 2
label :
4- then I did:
v.colors map=teste12 at Regional column=cat color=aspect
And I got:
ERROR: Column <cat> is not numeric
This is weird because, I get CATEGORY values.
5- Then I decided to add GRASSRGB column like this
v.db.addcolumn map=teste11 at Regional columns=GRASSRGB varchar(11)
and I got the following error
-: No such file or directory
ERROR: Unable to add column <GRASSRGB varchar(11)>.
Can anybody give me an hand on this?
Thanks
2010/11/15 Martin Landa <landa.martin at gmail.com>
> Hi,
> 2010/11/15 Luisa Peña <luisapena1979 at gmail.com>:
> >> download manually Python scripts v.colors [1] and v.db.addcolumn [2]
> >> and integrate them to your GRASS 6 installation. You have of course
> >> more possibilities
> > In This case, these are python scripts right? Ok I will give a try.
> they should be OK, if not, it's *much more* easier to fix them.
> >> 2) fix Bash scripts on Windows (keep in mind that these fixes will
> >> disappear in GRASS7 because it uses Python)
> > But, as far as I can see from this discussion, there is no FIX for this
> Read as: you fix them or convince someone to do it.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101115/ef4c5dfc/attachment.html
