[GRASS-user] r.shaded.relief-spgrass6 problems
Brian Oney
zenlines at gmail.com
Mon Nov 15 20:07:48 EST 2010
Thanks Chris,
but it returned the same error. I will note that for the future though.
I stuck to that because it was an example in the ps.map part of the wiki.
Brian
On 11/16/2010 2:04 AM, Chris Carleton wrote:
> Off the top of my head the '.' in your map name is causing problems.
> Technically, I think you can use any character (with a few exceptions)
> in map names, but it's better to avoid most of them and stick to
> alphanumeric and '_' to separate portions of the name.
> Chris
> On 15 November 2010 19:43, brian <zenlines at gmail.com
> <mailto:zenlines at gmail.com>> wrote:
> Hello List,
> I am having trouble parsing the r.shaded.relief module from R
> using the
> spgrass6 package.
> When doing it directly in GRASS, it works but an error is first
> returned. It
> goes as follows:
> r.shaded.relief map=alt shadedmap=elev.shad_relief altitude=80
> --overwrite
> basename: extra operand
> `(x86)/GRASS-65-SVN/scripts/r.shaded.relief'
> Try `basename --help' for more information.
> Calculating shading, please stand by.
> Color table for raster map <elev.shad_relief> set to 'grey'
> Shaded relief map created and named <elev.shad_relief>.
> This looks the same in R but this causes R to cease computation.
> The above
> command sent with R yields:
> > execGRASS("r.shaded.relief",flags="overwrite",
> parameters=list(map="alt",
> > altitude=80, shadedmap="elev.shad_relief"))
> Error : basename: extra operand
> <?xml version="1.0" encoding="CP1252"?>
> <!DOCTYPE task SYSTEM "grass-interface.dtd">
> </task> does not seem to be XML, nor to identify a file name
> Error in parseGRASS(cmd) : r.shaded.relief not parsed
> Is this a bug or my mistake?
> Thanks,
> Brian
> http://osgeo-org.1803224.n2.nabble.com/r-shaded-relief-spgrass6-problems-tp5742202p5742202.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101116/c7ad635e/attachment-0001.html
