[GRASS-user] r.shaded.relief-spgrass6 problems
Brian Oney zenlines at gmail.com
Mon Nov 15 21:08:00 EST 2010
Hi Chris,
no I didn't know that. I have my environment as such:
the initiation of the GRASS-R interface is as such:
initGRASS("C:/Program Files (x86)/GRASS-65-SVN", home=tempdir(),
gisDbase=gisDbase, location="VPH_PC", mapset=paste("Maps",sep=""),
override=T)
So the PATH should be "C:/Program Files (x86)/GRASS-65-SVN"
Could the space in "Program Files (x86)" be causing the problem?
execGRASS("g.gisenv")
GISDBASE='D:/GIS Database/';
LOCATION_NAME='VPH_PC';
MAPSET='Maps';
GRASS_GUI='text';
When looking at the r.shaded.relief script, I find no error to be
returned the say anything about an operand.
One parses when one messes with grass when it is calculating:
    g.message -e "In calculation, script aborted."
Another:
    g.message -e  "Map <$elev> not found."
and:
     g.message -e "Input elevation map and output relief map must have
different names"
hmm.... As I said GRASS carries out the command just fine. This may be a
problem with the XML package (a dependency of the spgrass6 package) or
spgrass6 package in that R halts the computation because it thinks that
GRASS is sending them an error. This post may belong in the grass-stats
list.
Thank you for the help and no reason to be sorry.
Regards,
Brian
On 11/16/2010 2:35 AM, Chris Carleton wrote:
> You may know this already, but the error seems to be saying something
> about problems with your PATH. What are your system specs? What is the
> full path to your GIS database that grass uses? There might be
> something irregular about your path, but it could also be that there
> is a typo in the shaded relief script that's in your SVN version (i.e.
> the unusual operand it's complaining about). Check out this webpage
> for more details
> http://www.opengroup.org/onlinepubs/9699919799/functions/basename.html
> and if you can't find the error then try the grass-dev mailing list.
> Glynn or Markus or one of the other developers will likely have a good
> idea about why the basename function is returning an error and where
> it is - in case you don't already know they are awesome when it comes
> to free online support for GRASS users. Hope it works out and sorry I
> couldn't be of more help.
> C
> On 15 November 2010 20:07, Brian Oney <zenlines at gmail.com
> <mailto:zenlines at gmail.com>> wrote:
>     Thanks Chris,
>     but it returned the same error. I will note that for the future
>     though. I stuck to that because it was an example in the ps.map
>     part of the wiki.
>     Brian
>     On 11/16/2010 2:04 AM, Chris Carleton wrote:
>>     Off the top of my head the '.' in your map name is causing
>>     problems. Technically, I think you can use any character (with a
>>     few exceptions) in map names, but it's better to avoid most of
>>     them and stick to alphanumeric and '_' to separate portions of
>>     the name.
>>     Chris
>>     On 15 November 2010 19:43, brian <zenlines at gmail.com
>>         Hello List,
>>         I am having trouble parsing the r.shaded.relief module from R
>>         using the
>>         spgrass6 package.
>>         When doing it directly in GRASS, it works but an error is
>>         first returned. It
>>         goes as follows:
>>         r.shaded.relief map=alt shadedmap=elev.shad_relief
>>         altitude=80 --overwrite
>>         basename: extra operand
>>         `(x86)/GRASS-65-SVN/scripts/r.shaded.relief'
>>         Try `basename --help' for more information.
>>         Calculating shading, please stand by.
>>         Color table for raster map <elev.shad_relief> set to 'grey'
>>         Shaded relief map created and named <elev.shad_relief>.
>>         This looks the same in R but this causes R to cease
>>         computation. The above
>>         command sent with R yields:
>>         > execGRASS("r.shaded.relief",flags="overwrite",
>>         parameters=list(map="alt",
>>         > altitude=80, shadedmap="elev.shad_relief"))
>>         Error : basename: extra operand
>>         <?xml version="1.0" encoding="CP1252"?>
>>         <!DOCTYPE task SYSTEM "grass-interface.dtd">
>>         </task>  does not seem to be XML, nor to identify a file name
>>         Error in parseGRASS(cmd) : r.shaded.relief not parsed
>>         Is this a bug or my mistake?
>>         Thanks,
>>         Brian
>>         View this message in context:
>>         http://osgeo-org.1803224.n2.nabble.com/r-shaded-relief-spgrass6-problems-tp5742202p5742202.html
>>         Sent from the Grass - Users mailing list archive at Nabble.com.
>>         _______________________________________________
>>         grass-user mailing list
>>         grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101116/4e10859b/attachment.html
