[GRASS-user] add-ons installation failure
Markus Metz markus.metz.giswork at googlemail.com
Tue Nov 16 07:26:35 EST 2010
On Tue, Nov 16, 2010 at 12:14 PM, Patrick_schirmer <patrick_GIS at gmx.ch> wrote:
> Dear list,
> I am trying to install add-ons on GRASS (6.4.0) through g.extension, as
> Markus mentioned this should be possible with RC07. Had to import grass-dev
> package,
Some of these grass-dev packages seem to have bugs introduced by the packagers:
in /usr/lib/grass64/include/Make/Platform.make, replace
# GRASS dirs
GRASS_HOME          = /build/buildd/grass-6.4.0
RUN_GISBASE         = /build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu
with
# GRASS dirs
GRASS_HOME          = /usr/lib/grass64
# not sure what should be here since
/usr/lib/grass64/dist.i486-pc-linux-gnu does not exist:
RUN_GISBASE         = /usr/lib/grass64
Then it should not be necessary to...
> create a directory "build" in directory "/" (which is not mentioned
> in wiki) and change rights to chmod -777 that it would start running.
and...
> When
> running g.extension extension=v.vectstats it creates following error:
> Compiling <v.vect.stats>...
> test -d OBJ.i486-pc-linux-gnu || mkdir -p OBJ.i486-pc-linux-gnu
> gcc -I/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/include -Wall -g -O
> -I/usr/include/gdal -DPACKAGE=\""grassmods"\"
> -I/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/include -o
the non-existing path
should be replaced with the existing path
HTH,
Markus M
> OBJ.i486-pc-linux-gnu/main.o -c main.c
> main.c:23:23: error: grass/gis.h: No such file or directory
> main.c:24:27: error: grass/glocale.h: No such file or directory
> main.c:25:25: error: grass/stats.h: No such file or directory
> main.c:26:24: error: grass/dbmi.h: No such file or directory
> main.c:27:24: error: grass/Vect.h: No such file or directory
> main.c:31: error: expected specifier-qualifier-list before ‘stat_func’
> main.c:39: error: ‘c_sum’ undeclared here (not in a function)
> (complete log file is attached)
> Do I need to set some other paths before? I still try to avoid installing
> GRASS from svn.
> Wiki-link:
> http://josef.fsv.cvut.cz/WIKI/grass-osgeo/index.php/GRASS_AddOns#Building_and_installing_Addons
> Thanks for your kind help
> Patrick (Schirmer)
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
