[GRASS-user] add-ons installation failure
    Markus Metz
    markus.metz.giswork at googlemail.com
    Tue Nov 16 07:41:13 EST 2010
I forgot...
On Tue, Nov 16, 2010 at 1:26 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> On Tue, Nov 16, 2010 at 12:14 PM, Patrick_schirmer <patrick_GIS at gmx.ch> wrote:
>> Dear list,
>> I am trying to install add-ons on GRASS (6.4.0) through g.extension, as
>> Markus mentioned this should be possible with RC07. Had to import grass-dev
>> package,
> Some of these grass-dev packages seem to have bugs introduced by the packagers:
> in /usr/lib/grass64/include/Make/Platform.make, replace
> # GRASS dirs
> GRASS_HOME          = /build/buildd/grass-6.4.0
> RUN_GISBASE         = /build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu
> with
> # GRASS dirs
> GRASS_HOME          = /usr/lib/grass64
> # not sure what should be here since
> /usr/lib/grass64/dist.i486-pc-linux-gnu does not exist:
> RUN_GISBASE         = /usr/lib/grass64
and in /usr/lib/grass64/include/Make/GRASS.make, you may need to replace
# GRASS global directories and constants
# platform specific dirs
ARCH_DISTDIR	= $(GRASS_HOME)/dist.$(ARCH)
ARCH_BINDIR     = $(GRASS_HOME)/bin.$(ARCH)
ERRORLOG        = $(GRASS_HOME)/error.log
with
# point ERRORLOG to somewhere at home, e.g. current dir ???
ERRORLOG        = grass64_error.log
completely untested, just a guess
Markus M
> Then it should not be necessary to...
>> create a directory "build" in directory "/" (which is not mentioned
>> in wiki) and change rights to chmod -777 that it would start running.
> and...
>> When
>> running g.extension extension=v.vectstats it creates following error:
>> Compiling <v.vect.stats>...
>> test -d OBJ.i486-pc-linux-gnu || mkdir -p OBJ.i486-pc-linux-gnu
>> gcc -I/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/include -Wall -g -O
>> -I/usr/include/gdal -DPACKAGE=\""grassmods"\"
>> -I/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/include -o
> the non-existing path
> should be replaced with the existing path
> HTH,
> Markus M
>> OBJ.i486-pc-linux-gnu/main.o -c main.c
>> main.c:23:23: error: grass/gis.h: No such file or directory
>> main.c:24:27: error: grass/glocale.h: No such file or directory
>> main.c:25:25: error: grass/stats.h: No such file or directory
>> main.c:26:24: error: grass/dbmi.h: No such file or directory
>> main.c:27:24: error: grass/Vect.h: No such file or directory
>> main.c:31: error: expected specifier-qualifier-list before ‘stat_func’
>> main.c:39: error: ‘c_sum’ undeclared here (not in a function)
>> (complete log file is attached)
>> Do I need to set some other paths before? I still try to avoid installing
>> GRASS from svn.
>> Wiki-link:
>> http://josef.fsv.cvut.cz/WIKI/grass-osgeo/index.php/GRASS_AddOns#Building_and_installing_Addons
>> Thanks for your kind help
>> Patrick (Schirmer)
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
