[GRASS-user] Re: Warning from v.digit- Unable to read
Maris Nartiss
maris.gis at gmail.com
Thu Nov 18 06:42:47 EST 2010
Hello,
eliminating this warning is not an easy task. As far I can see,
v.digit running under Linux does NOT call v.build for two times, still
it does for windows. Unless somebody running WinGRASS decides to spend
some time by recompiling and testing v.digit to see the cause of
double v.build processing, there's nothing we can do.
Only proper solution for You, is to use any normal operating system (GNU/Linux).
Guess: Issue could be related to tk . <Destory> binding. On Linux it
doesn't fire on Exit from application, still I have no idea if on
Windows it works in different way.
Maris.
2010/11/17, Luisa Peña <luisapena1979 at gmail.com>:
> This was a matter discussed in the past (
> http://trac.osgeo.org/grass/ticket/917).
> I'm still obtaining the same message. I'm willing to eliminate this warning.
> >From which function is it printed because, I have searched in V.digit and
> nothing was gfound
> Thanks
> luisa
> 2010/8/3 Luisa Peña <luisapena1979 at gmail.com>
>> I'm running v.digit in Windows and, after I draw my boundaries in TclTk's
>> digitizer, when I close I get this warning in v.digit command output tab:
>> Unable to read vector map
>> But my vectorial is created without problems. Why is tbhis printed? And
>> how
>> can I avoid it?
>> Thanks
>> Luisa
