[GRASS-user] Re: Warning from v.digit- Unable to read
Markus Metz
markus.metz.giswork at googlemail.com
Thu Nov 18 06:48:35 EST 2010
Maris Nartiss wrote:
> Hello,
> eliminating this warning is not an easy task. As far I can see,
> v.digit running under Linux does NOT call v.build for two times, still
> it does for windows. Unless somebody running WinGRASS decides to spend
> some time by recompiling and testing v.digit to see the cause of
> double v.build processing, there's nothing we can do.
> Only proper solution for You, is to use any normal operating system (GNU/Linux).
The warning seems to be harmless because topology has been
successfully built in the first attempt and the vector map closed. The
second attempt to build topology fails because the vector map has been
closed. The warning is IMHO annoying but can be ignored (so far).
Markus M
> Guess: Issue could be related to tk . <Destory> binding. On Linux it
> doesn't fire on Exit from application, still I have no idea if on
> Windows it works in different way.
> Maris.
> 2010/11/17, Luisa Peña <luisapena1979 at gmail.com>:
>> This was a matter discussed in the past (
>> http://trac.osgeo.org/grass/ticket/917).
>> I'm still obtaining the same message. I'm willing to eliminate this warning.
>> >From which function is it printed because, I have searched in V.digit and
>> nothing was gfound
>> Thanks
>> luisa
>> 2010/8/3 Luisa Peña <luisapena1979 at gmail.com>
>>> I'm running v.digit in Windows and, after I draw my boundaries in TclTk's
>>> digitizer, when I close I get this warning in v.digit command output tab:
>>> Unable to read vector map
>>> But my vectorial is created without problems. Why is tbhis printed? And
>>> how
>>> can I avoid it?
>>> Thanks
>>> Luisa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
