[GRASS-user] v.rast.stats over a large vector file
Markus Metz
markus.metz.giswork at googlemail.com
Mon Nov 29 02:31:58 EST 2010
Hamish wrote:
> ps- v.rast.stats2 from svn addons should now be working for all
Unfortunately not, I still get an awk error about an unterminated string.
Now that the shebang is #!/bin/bash, is the original way to create an
array now safe?
--- v.rast.stats2 (revision 44471)
+++ v.rast.stats2 (working copy)
@@ -347,7 +347,7 @@
done
# create array with new column names
-col=`cat "$COLNAMETMP" | tr '\n' ' '`
+col=(`cat "$COLNAMETMP" | tr '\n' ' '`)
# create SQL file for extended and normal statistics
g.message -v "Creating SQL file ..."
Markus M
