[GRASS-user] WinGRASS: Error when importing GRIB files
antonio.rocha at deimos.com.pt
Mon Nov 29 17:56:09 EST 2010
Hello
Thanks Ricardo. That is the problem. My GDAL, installed withg OSGEO4w
is not able to open/process GRIB files.
Has anyone changed GDAL version in OSGEO4w in Windows?
Thanks
Antonio
Quoting "Ricardo Filipe Soares Garcia da" <ricardo.garcia.silva at gmail.com>:
> Olá António
> On my windows VM, I have an older osgeo4w install, that hasn't got
> GRIB support available. Maybe thats your problem as well? Run the
> command
> gdalinfo --formats
> through the osgeo4w shell. Look for the GRIB format at the output.
> If you cannot find a line that says GRIB there, your GDAL doesn't
> support it, and GRASS won't be able to read it, as it depends on GDAL.
> 2010/11/29 António Rocha <antonio.rocha at deimos.com.pt>:
>> Hi
>> I'm using WinGRASS (6.4.1) in Osgeo4w and I'm having a problem in the import
>> of GRIB files. I'm using r.in.gdal, as I have used in Linux, and I'm
>> obtaining the following error:
>> ERROR 4: `C:\Data\GISDataBase\GRIB_codes\new03.grib' not
>> recognised as a supported file format.
>> What might be missing?
>> Thanks
>> Antonio
>> __________ Information from ESET NOD32 Antivirus, version of virus signature
>> database 5657 (20101129) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> ___________________________ ___ __
> Ricardo Garcia Silva
