[GRASS-user] r.univar.zonal not installing
Vishal Mehta vishalm1975 at gmail.com
Tue Oct 5 19:52:07 EDT 2010
Hi Markus,
I got the exact same error message as Laura, when trying to use g.extension:
this is what i get (below). I'm afraid I did not follow your solution to the
problem? - Vishal
* g.extension r.univar2.zonal
Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
A    r.univar2.zonal/stats.c
A    r.univar2.zonal/sort.c
A    r.univar2.zonal/globals.h
A    r.univar2.zonal/r.univar.zonal.html
A    r.univar2.zonal/r.univar_main.c
A    r.univar2.zonal/r3.univar.zonal.html
A    r.univar2.zonal/r3.univar_main.c
A    r.univar2.zonal/Makefile
 U   r.univar2.zonal
Checked out revision 43800.
Compiling <r.univar2.zonal>...
make[3]: Leaving directory
`/home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/17635.0/r.univar2.zonal'
make[2]: Leaving directory
make[1]: Leaving directory
Installing r.univar2.zonal...
if [ "" != "" ] ; then \
        for dir in  ; do \
            make -C $dir install ; \
        done ; \
    fi
ERROR: Module did not install properly
On Tue, Oct 5, 2010 at 12:17 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Aug 9, 2010 at 5:41 PM, Laura Poggio <laura.poggio at gmail.com>
> wrote:
> > Dear all,
> > since a while, I am trying to compile the r.univar.zonal addon on a
> Fedora11
> > 64 bit machine and using GRASS 6.5
> > I used:
> > svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
> > cd r.univar2.zonal/
> > make MODULE_TOPDIR=~/bin/grass65/grass6_devel/
> > No errors were detected, but when I try:
> > make MODULE_TOPDIR=/home/myuser/bin/grass65/grass6_devel install
> > I am getting:
> >                 for dir in  ; do \
> >                 done ; \
> >         fi
> > Various other addons were installed using these steps, then I think I am
> > missing something here ... Thank you in advance for any hints!
> Perhaps that comes from the directory name which I find slightly confusing:
> GRASS 6.4.1svn (nc_spm_08):~ > ls -la grass-addons/raster/r.univar2.zonal/
> total 76
> drwxr-xr-x  3 neteler neteler  4096 2010-02-18 21:40 ./
> drwxr-xr-x 53 neteler neteler  4096 2010-09-23 12:04 ../
> -rw-r--r--  1 neteler neteler  1806 2010-02-18 21:36 globals.h
> -rw-r--r--  1 neteler neteler   624 2009-04-09 10:44 Makefile
> -rw-r--r--  1 neteler neteler  8426 2010-02-18 21:36 r3.univar_main.c
> -rw-r--r--  1 neteler neteler  2286 2010-02-18 21:36 r3.univar.zonal.html
> -rw-r--r--  1 neteler neteler  9829 2010-02-18 21:36 r.univar_main.c
> -rw-r--r--  1 neteler neteler  4411 2009-04-09 10:44 r.univar.zonal.html
> -rw-r--r--  1 neteler neteler  3358 2009-02-24 08:27 sort.c
> -rw-r--r--  1 neteler neteler 15223 2010-02-18 21:36 stats.c
> drwxr-xr-x  6 neteler neteler  4096 2010-09-22 09:25 .svn/
> GRASS 6.4.1svn (nc_spm_08):~ > grep univ
> grass-addons/raster/r.univar2.zonal/Makefile
> PROGRAMS = r.univar.zonal r3.univar.zonal
> R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
> RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
> $(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
> $(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
> -> PROGRAMS that does not reflect the directory name.
> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar.zonal
> WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
> Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
> svn: URL 'https://svn.osgeo.org/grass/grass-addons/raster/r.univar.zonal'
> doesn't exist
> ERROR: GRASS Add-on r.univar.zonal not found in repository or no network
>       connection or another problem
> But like this it works:
> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar2.zonal
>  U   r.univar2.zonal
> Checked out revision 43799.
> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
> gcc -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include  -g
> -Wall  -fno-common -fexceptions -mtune=nocona -m64
> -minline-all-stringops       -DPACKAGE=\""grassmods"\"
> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
> OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
> Proposals
> @authors: rename directory to first program name
> @Laura: please try g.extension
> best,
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101005/179d2a79/attachment.html
