[GRASS-user] help with georectify
Stuart Edwards
sedwards2 at cinci.rr.com
Wed Oct 6 09:23:17 EDT 2010
Hi ~
GRASS 6.4.0 / OS X 10.6.4 and 10.5.8 (PPC) with wxpython
I'm having a problem with the georectify module - which is strange since I've used it a lot in the past without any problems; although maybe not since I upgraded to this GRASS version - hard to remember. The module executes smoothly through the selection of GCPs and will compute an rms error. However, when the georectify button is activated I get an error message stating that the Group does not exist. Right above this message is a line from i.points stating that the points file was saved for this group -- i.e.
POINTS file </Users/stu/grassdata/xy2/PERMANENT/group/sheet9/POINTS> saved
(Wed Oct 6 09:03:44 2010)
i.rectify -a group=sheet9 extension=georect64214 order=1
ERROR: Group <sheet9> does not exist
(Wed Oct 6 09:03:44 2010) Command finished (0 sec)
This looks a little like a bug that was identified last year and fixed (# 689 / # 709)
BTW, what is the complex 'extension' and why is the auto-generated value so 'complex'
Thanks for any assistance .......
Stu
