[GRASS-user] help with georectify
Pablo Carreira pablotcarreira at hotmail.com
Wed Oct 6 14:39:30 EDT 2010
Sometimes I have the same problem.
My solution is to use the georectify module to set the GPCs, save, close it and then run:i.group - i.target - i.rectfy.It's fail safe.
Pablo Torres Carreira
> From: sedwards2 at cinci.rr.com
> Date: Wed, 6 Oct 2010 09:23:17 -0400
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] help with georectify
> Hi ~
> GRASS 6.4.0 / OS X 10.6.4 and 10.5.8 (PPC) with wxpython
> I'm having a problem with the georectify module - which is strange since I've used it a lot in the past without any problems; although maybe not since I upgraded to this GRASS version - hard to remember.  The module executes smoothly through the selection of GCPs and will compute an rms error.  However, when the georectify button is activated I get an error message stating that the Group does not exist.  Right above this message is a line from i.points stating that the points file was saved for this group -- i.e.
> POINTS file </Users/stu/grassdata/xy2/PERMANENT/group/sheet9/POINTS> saved
> (Wed Oct  6 09:03:44 2010)
> i.rectify -a group=sheet9 extension=georect64214 order=1
> ERROR: Group <sheet9> does not exist
> (Wed Oct  6 09:03:44 2010) Command finished (0 sec)
> This looks a little like a bug that was identified last year and fixed (# 689 / # 709)
> BTW, what is the complex 'extension' and why  is the auto-generated value so 'complex'
> Thanks for any assistance .......
> Stu_______________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101006/9b8df182/attachment.html
