[GRASS-user] r.univar.zonal not installing
Laura Poggio
laura.poggio at gmail.com
Tue Oct 12 04:41:05 EDT 2010
Hi Vishal,
I recompiled grass from sources because I also wanted to update it to the
most recent release. I now installed r.univar.zonal on two different
computers and it worked fine. But I recompiled grass each time.
Laura
On 11 October 2010 20:41, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> Hi Laura,
> Did you have to recompile an updated Grass65 from svn?
> I am still unable to install this either from g.extension or compiling it
> from source..
> Vishal
> On Fri, Oct 8, 2010 at 1:43 AM, Laura Poggio <laura.poggio at gmail.com>wrote:
>> Dear all,
>> it worked using g.extension on an updated version of GRASS65.
>> Sorry for my late answer but in the past days I was unable to try.
>> Thank you
>> Laura
>> On 5 October 2010 20:17, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Mon, Aug 9, 2010 at 5:41 PM, Laura Poggio <laura.poggio at gmail.com>
>>> wrote:
>>> > Dear all,
>>> > since a while, I am trying to compile the r.univar.zonal addon on a
>>> Fedora11
>>> > 64 bit machine and using GRASS 6.5
>>> > I used:
>>> > svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
>>> > cd r.univar2.zonal/
>>> > make MODULE_TOPDIR=~/bin/grass65/grass6_devel/
>>> > No errors were detected, but when I try:
>>> > make MODULE_TOPDIR=/home/myuser/bin/grass65/grass6_devel install
>>> > I am getting:
>>> > if [ "" != "" ] ; then \
>>> > for dir in ; do \
>>> > make -C $dir install ; \
>>> > done ; \
>>> > fi
>>> > Various other addons were installed using these steps, then I think I
>>> am
>>> > missing something here ... Thank you in advance for any hints!
>>> Perhaps that comes from the directory name which I find slightly
>>> confusing:
>>> GRASS 6.4.1svn (nc_spm_08):~ > ls -la
>>> grass-addons/raster/r.univar2.zonal/
>>> total 76
>>> drwxr-xr-x 3 neteler neteler 4096 2010-02-18 21:40 ./
>>> drwxr-xr-x 53 neteler neteler 4096 2010-09-23 12:04 ../
>>> -rw-r--r-- 1 neteler neteler 1806 2010-02-18 21:36 globals.h
>>> -rw-r--r-- 1 neteler neteler 624 2009-04-09 10:44 Makefile
>>> -rw-r--r-- 1 neteler neteler 8426 2010-02-18 21:36 r3.univar_main.c
>>> -rw-r--r-- 1 neteler neteler 2286 2010-02-18 21:36 r3.univar.zonal.html
>>> -rw-r--r-- 1 neteler neteler 9829 2010-02-18 21:36 r.univar_main.c
>>> -rw-r--r-- 1 neteler neteler 4411 2009-04-09 10:44 r.univar.zonal.html
>>> -rw-r--r-- 1 neteler neteler 3358 2009-02-24 08:27 sort.c
>>> -rw-r--r-- 1 neteler neteler 15223 2010-02-18 21:36 stats.c
>>> drwxr-xr-x 6 neteler neteler 4096 2010-09-22 09:25 .svn/
>>> GRASS 6.4.1svn (nc_spm_08):~ > grep univ
>>> grass-addons/raster/r.univar2.zonal/Makefile
>>> PROGRAMS = r.univar.zonal r3.univar.zonal
>>> R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
>>> RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
>>> $(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
>>> $(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o
>>> $(OBJDIR)/stats.o
>>> -> PROGRAMS that does not reflect the directory name.
>>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar.zonal
>>> WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
>>> Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
>>> svn: URL 'https://svn.osgeo.org/grass/grass-addons/raster/r.univar.zonal
>>> doesn't exist
>>> ERROR: GRASS Add-on r.univar.zonal not found in repository or no network
>>> connection or another problem
>>> But like this it works:
>>> $(OBJDIR)/stats.o
>>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar2.zonal
>>> Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
>>> A r.univar2.zonal/stats.c
>>> A r.univar2.zonal/sort.c
>>> A r.univar2.zonal/globals.h
>>> A r.univar2.zonal/r.univar.zonal.html
>>> A r.univar2.zonal/r.univar_main.c
>>> A r.univar2.zonal/r3.univar.zonal.html
>>> A r.univar2.zonal/r3.univar_main.c
>>> A r.univar2.zonal/Makefile
>>> U r.univar2.zonal
>>> Checked out revision 43799.
>>> Compiling <r.univar2.zonal>...
>>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
>>> gcc -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -g
>>> -Wall -fno-common -fexceptions -mtune=nocona -m64
>>> -minline-all-stringops -DPACKAGE=\""grassmods"\"
>>> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
>>> OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
>>> Proposals
>>> @authors: rename directory to first program name
>>> @Laura: please try g.extension
>>> best,
>>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Vishal K. Mehta, PhD
> Scientist
> Stockholm Environment Institute - US
> 133 D St Suite F
> Davis CA 95616
> www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101012/028b24e8/attachment-0001.html
