[GRASS-user] r.univar.zonal not installing
Markus Metz markus.metz.giswork at googlemail.com
Tue Oct 12 05:09:24 EDT 2010
BTW, r.univar in 6.5 and 7 has been updated with the functionality of
r.univar.zonal. Of course r.univar behaves as before without the
options for zonal statistics. IOW, r.univar.zonal is only needed for
6.4.
Markus M
On Tue, Oct 12, 2010 at 10:41 AM, Laura Poggio <laura.poggio at gmail.com> wrote:
> Hi Vishal,
> I recompiled grass from sources because I also wanted to update it to the
> most recent release. I now installed r.univar.zonal on two different
> computers and it worked fine. But I recompiled grass each time.
> Laura
> On 11 October 2010 20:41, Vishal Mehta <vishalm1975 at gmail.com> wrote:
>> Hi Laura,
>> Did you have to recompile an updated Grass65 from svn?
>> I am still unable to install this either from g.extension or compiling it
>> from source..
>> Vishal
>> On Fri, Oct 8, 2010 at 1:43 AM, Laura Poggio <laura.poggio at gmail.com>
>> wrote:
>>> Dear all,
>>> it worked using g.extension on an updated version of GRASS65.
>>> Sorry for my late answer but in the past days I was unable to try.
>>> Thank you
>>> Laura
>>> On 5 October 2010 20:17, Markus Neteler <neteler at osgeo.org> wrote:
>>>> On Mon, Aug 9, 2010 at 5:41 PM, Laura Poggio <laura.poggio at gmail.com>
>>>> wrote:
>>>> > Dear all,
>>>> > since a while, I am trying to compile the r.univar.zonal addon on a
>>>> > Fedora11
>>>> > 64 bit machine and using GRASS 6.5
>>>> > I used:
>>>> > svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
>>>> > cd r.univar2.zonal/
>>>> > make MODULE_TOPDIR=~/bin/grass65/grass6_devel/
>>>> > No errors were detected, but when I try:
>>>> > make MODULE_TOPDIR=/home/myuser/bin/grass65/grass6_devel install
>>>> > I am getting:
>>>> > if [ "" != "" ] ; then \
>>>> >                 for dir in  ; do \
>>>> >                         make -C $dir install ; \
>>>> >                 done ; \
>>>> >         fi
>>>> > Various other addons were installed using these steps, then I think I
>>>> > am
>>>> > missing something here ... Thank you in advance for any hints!
>>>> Perhaps that comes from the directory name which I find slightly
>>>> confusing:
>>>> GRASS 6.4.1svn (nc_spm_08):~ > ls -la
>>>> grass-addons/raster/r.univar2.zonal/
>>>> total 76
>>>> drwxr-xr-x  3 neteler neteler  4096 2010-02-18 21:40 ./
>>>> drwxr-xr-x 53 neteler neteler  4096 2010-09-23 12:04 ../
>>>> -rw-r--r--  1 neteler neteler  1806 2010-02-18 21:36 globals.h
>>>> -rw-r--r--  1 neteler neteler   624 2009-04-09 10:44 Makefile
>>>> -rw-r--r--  1 neteler neteler  8426 2010-02-18 21:36 r3.univar_main.c
>>>> -rw-r--r--  1 neteler neteler  2286 2010-02-18 21:36
>>>> r3.univar.zonal.html
>>>> -rw-r--r--  1 neteler neteler  9829 2010-02-18 21:36 r.univar_main.c
>>>> -rw-r--r--  1 neteler neteler  4411 2009-04-09 10:44 r.univar.zonal.html
>>>> -rw-r--r--  1 neteler neteler  3358 2009-02-24 08:27 sort.c
>>>> -rw-r--r--  1 neteler neteler 15223 2010-02-18 21:36 stats.c
>>>> drwxr-xr-x  6 neteler neteler  4096 2010-09-22 09:25 .svn/
>>>> GRASS 6.4.1svn (nc_spm_08):~ > grep univ
>>>> grass-addons/raster/r.univar2.zonal/Makefile
>>>> PROGRAMS = r.univar.zonal r3.univar.zonal
>>>> R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
>>>> RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
>>>> $(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
>>>> $(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o
>>>> $(OBJDIR)/stats.o
>>>> -> PROGRAMS that does not reflect the directory name.
>>>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar.zonal
>>>> WARNING: GRASS_ADDON_PATH is not defined, installing to
>>>> ~/.grass6/addons/
>>>> Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
>>>> svn: URL
>>>> 'https://svn.osgeo.org/grass/grass-addons/raster/r.univar.zonal'
>>>> doesn't exist
>>>> ERROR: GRASS Add-on r.univar.zonal not found in repository or no network
>>>>       connection or another problem
>>>> But like this it works:
>>>> $(OBJDIR)/stats.o
>>>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar2.zonal
>>>> ~/.grass6/addons/
>>>> Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
>>>> A    r.univar2.zonal/stats.c
>>>> A    r.univar2.zonal/sort.c
>>>> A    r.univar2.zonal/globals.h
>>>> A    r.univar2.zonal/r.univar.zonal.html
>>>> A    r.univar2.zonal/r.univar_main.c
>>>> A    r.univar2.zonal/r3.univar.zonal.html
>>>> A    r.univar2.zonal/r3.univar_main.c
>>>> A    r.univar2.zonal/Makefile
>>>>  U   r.univar2.zonal
>>>> Checked out revision 43799.
>>>> Compiling <r.univar2.zonal>...
>>>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
>>>> gcc -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include  -g
>>>> -Wall  -fno-common -fexceptions -mtune=nocona -m64
>>>> -minline-all-stringops       -DPACKAGE=\""grassmods"\"
>>>> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
>>>> OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
>>>> Proposals
>>>> @authors: rename directory to first program name
>>>> @Laura: please try g.extension
>>>> best,
>>>> Markus
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Vishal K. Mehta, PhD
>> Scientist
>> Stockholm Environment Institute - US
>> 133 D St Suite F
>> Davis CA 95616
>> www.sei-us.org
