Jarosław Jasiewicz wrote: > The reason of your error is that you have extremely dense drainage > network on rather low resolution dem. > all you can do is to modify source code Hi, ok, thanks a lot I'll try Francesco >> >> >> ------------------------------------------------------------------------ >> >> >
