[GRASS-user] Startup error with 6.4.1svn on OSX 10.6.4
Stuart Edwards
sedwards2 at cinci.rr.com
Thu Oct 14 16:01:22 EDT 2010
On Oct 14, 2010, at 2:51 PM, William Kyngesburye wrote:
> ... Oh! You say you used 6.4.0 before - was this my package?
Indeed
> When you install 6.4.1 from source, it's installing on top of my 6.4.0.
And quite a mess I made ; -(
> And probably leaving the bundled wx libraries already there, but removing the bundled wxpython, so when it tried to use the system wxpython it found the leftover bundled wx libraries.
> Try deleting the old GRASS application before installing your GRASS compiled from source.
Actually, I've had to download and reinstall your binaries just to get a working version going again - so I'm not inclined to risk losing my production setup. Can I give the current 6.4.0 a different name or does it have to be completely gone? I may well put this project on hold for a while.
BTW, thank you for maintaining such a fine repository of reliable binaries ......
> On Oct 14, 2010, at 1:41 PM, Stuart Edwards wrote:
>> On Oct 14, 2010, at 11:36 AM, William Kyngesburye wrote:
>>>>> The GRASS package seems to be incomplete - it's running the system wxpython, but linking the bundled wx libraries, which are probably much newer and incompatible with the system. If both wxpython and wx libraries are bundled, then maybe the bundled wxpython is not in the python path (it should be in etc/python in the GRASS app package).
>>>>> Did you build from source? Or install a binary (I think Michael Barton has a svn binary available)?
>>>> Yes, from source.
>>> Are you using the system wxpython or did you install a binary from wxpython.org? (note: the system wxpython is a bit old, though it fits the minimum needed for GRASS)
>> It's the system wxpython
>>> Are you explicitly bundling wxpython? If not, it's odd that it thinks the wx libraries are bundled (the "expected in..." part of the error).
>> No, I did the export nad2bin line and then configured with the given (long) ./configure (which doesn't appear to mention python or wxpython........)
>> I did not do the '--with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-x.x.x.x/bin/wx-config modification
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
