[GRASS-user] Startup error with 6.4.1svn on OSX 10.6.4
William Kyngesburye
woklist at kyngchaos.com
Thu Oct 14 17:03:28 EDT 2010
On Oct 14, 2010, at 3:01 PM, Stuart Edwards wrote:
>> And probably leaving the bundled wx libraries already there, but removing the bundled wxpython, so when it tried to use the system wxpython it found the leftover bundled wx libraries.
>> Try deleting the old GRASS application before installing your GRASS compiled from source.
> Actually, I've had to download and reinstall your binaries just to get a working version going again - so I'm not inclined to risk losing my production setup. Can I give the current 6.4.0 a different name or does it have to be completely gone? I may well put this project on hold for a while.
You can rename the existing GRASS, say "GRASS-6.4.0.app".
Once you compile and install 6.4.1 (as GRASS-6.4.app), if you use Qgis it should continue to work using the new GRASS.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
