[GRASS-user] Changing raster boundaries
Micha Silver micha at arava.co.il
Fri Oct 15 02:21:50 EDT 2010
On 10/15/2010 12:20 AM, Nikos Alexandris wrote:
> Christian:
>>> Hi GRASS users,
>>> how to change the boundaries of a raster map (simply expand the
>>> border) without any automatic modification of map resolution as it
>>> will happen when using "r.region map=.. n= ..s=.. w= e=.." ?
>>> Thanks for some hint.
> Micha:
>> How about changing the current region with g.region, then use r.mapcalc
>> to create a copy of the original at the new extents?
> A reminder that "r.region" might be useful as well in this case.
Yes, but the OP asked not to use r.region since it changes also the
resolution. It recalculates the res so as to keep the same number of
rows and columns.
> Kind regards, Nikos
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
