[GRASS-user] Changing raster boundaries
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Oct 15 04:50:12 EDT 2010
Christian:
> >>> how to change the boundaries of a raster map (simply expand the
> >>> border) without any automatic modification of map resolution as it
> >>> will happen when using "r.region map=.. n= ..s=.. w= e=.." ?
> >>> Thanks for some hint.
Micha:
> >> How about changing the current region with g.region, then use r.mapcalc
> >> to create a copy of the original at the new extents?
On 10/15/2010 12:20 AM, Nikos Alexandris wrote:
> > A reminder that "r.region" might be useful as well in this case.
Micha:
> Yes, but the OP asked not to use r.region since it changes also the
> resolution. It recalculates the res so as to keep the same number of
> rows and columns.
Correct. My bad.
Thought the "r.region map=mymap n=n+100 e=e+100 w=w+100 s=s+100" will get the
job done and avoid (carefully) using g.region + r.mapcalc.
Regards, Nikos
