[GRASS-user] Re: Wingrass 6.4 with MSYS does not work
Daniel Victoria
daniel.victoria at gmail.com
Mon Oct 18 08:33:18 EDT 2010
Sorry to revive a very old tread but I just found out why WinGrass was
not working for me so I though I should documment it somehow. I had a
leftover environment variable due to an old Cygwin instal but it was
NOT in the system path... There was a variable called CYGWIN with the
value set to tty. I removed that and now everything works.
Cheers
Daniel
On Tue, Jul 6, 2010 at 1:05 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> I have no idea how mingw got into the path. Can't find it in my system
> environment variables. removing it from the path will not change the
> GNU Bash (Cygwin) line but now I don't see that bunch of python erros
> on screen. All it does is, after I select the location, it will start
> grass, tell me that wxvdigit does not work in windows and then gives
> me a Goodbye from Grass. The next line shows:
> $ Quit wxGUI. Grass is not running.
> Could other python installs be messing this up (python 2.4 from ArcGIS)?
> Thanks
> Daniel
> On Tue, Jul 6, 2010 at 10:47 AM, Luigi Ponti <lponti at inbox.com> wrote:
>> Dear Daniel,
>> On 06/07/2010 14:03, Daniel Victoria wrote:
>>> Another thing I just noticed looking at grass64svn script
>>> ArcGIS has set the variable PYTHONPATH=C:\Program Files (x86)\ArcGIS\bin
>> I don't know, but there seem to be no "PYTHONPATH" string in the my GRASS
>> installation folder.
>>> Could that be related?
>>> On Tue, Jul 6, 2010 at 8:54 AM, Daniel Victoria
>>>> Hi all,
>>>> I don't see any leftover cygwin instalation in my path. I even tried
>>>> removing python(xy) to see if that was the culprit.
>>>> Here are some of the environmental variables set in the msys shell
>>>> that I believe influences grass:
>>>> PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/c/Program
>>>> Files (x86)/OpenSSH/bin:/c/Windows/System32
>> There is a mingw thing that may be where bash.exe comes from. Why do you
>> need mingw in GRASS MSys? Wingrass has its own copy of MSys, and should not
>> need to point to /mingw/bin or anything else related to unix shell.
>> Kind regards,
>> Luigi
