[GRASS-user] output file location
Sandile Gumede
akasandile at gmail.com
Tue Oct 19 09:18:28 EDT 2010
Hi
Thanks, for grass module v.rast.stats vect=catchments1 rast=rain1
colpre=precip , is it the output file that I'm looking for in the path
below? If so which program is used to open it, I'm using ubuntu 9.04, my
default GRASS database is DBMF
$LOCATION_NAME/$MAPSET/dbf/catchments1.dbf
On Tue, Oct 19, 2010 at 2:52 PM, Micha Silver <micha at arava.co.il> wrote:
> Sandile Gumede wrote:
> Hello
>> Where do I get the output file which contains all the output for the
>> script below, the actual file name under my Mapset?
>> Maps output by GRASS are part of the GRASS database. Each vector or
> raster is not a single file, but rather a directory which contains several
> files. Each vector map has a directory under $LOCATION_NAME/$MAPSET/vector/
> and it might also have a dbf entry or an sqlite table for attributes. The
> parts of a raster map are split among a few directories:
> $LOCATION_NAME/$MAPSET/cats , $LOCATION_NAME/$MAPSET/cell ,
> $LOCATION_NAME/$MAPSET/hist etc.
> Micha
Kind Regards
TS Gumede | CSIR | Meraka Institute | ICT4EO Research Group
Office Tel: 012 841 2606 | mobile : 072 258 1650
*"Work like a slave in order to live like a King" ~ Unknown*
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101019/940abb1b/attachment-0001.html
