[GRASS-user] Re: output file location
Micha Silver micha at arava.co.il
Tue Oct 19 09:37:26 EDT 2010
Sandile Gumede wrote:
> Hi
> Thanks, for grass module v.rast.stats vect=catchments1 rast=rain1
> colpre=precip , is it the output file that I'm looking for in the path
> below? If so which program is used to open it, I'm using ubuntu 9.04,
> my default GRASS database is DBMF
> $LOCATION_NAME/$MAPSET/dbf/catchments1.dbf
If you're looking for only the attribute table, then yes, that's the file.
You can open it with OpenOffice Calc. Also you can see the whole table
and export to a text file with v.db.select catchments1.
> On Tue, Oct 19, 2010 at 2:52 PM, Micha Silver <micha at arava.co.il
>         Hello
>         Where do I get the output file which contains all the output
>         for the script below, the actual file name under my Mapset?
>     Maps output by GRASS are part of the GRASS database. Each vector
>     or raster is not a single file, but rather a directory which
>     contains several files. Each vector map has a directory under
>     $LOCATION_NAME/$MAPSET/vector/ and it might also have a dbf entry
>     or an sqlite table for attributes. The parts of a raster map are
>     split among a few directories: $LOCATION_NAME/$MAPSET/cats ,
>     $LOCATION_NAME/$MAPSET/cell , $LOCATION_NAME/$MAPSET/hist etc.
>     Micha
> Kind Regards
> TS Gumede | CSIR | Meraka Institute | ICT4EO Research Group
> Office Tel: 012 841 2606 | mobile : 072 258 1650
> /"Work like a slave in order to live like a King" ~ Unknown/
> This mail was received via Mail-SeCure System.
