[GRASS-user] Use of r.mode
Micha Silver
micha at arava.co.il
Tue Oct 19 13:52:09 EDT 2010
On 10/19/2010 04:03 PM, Monica Buescu wrote:
> Hi Mich
> Thanks for the reply. I think it has worked but everytime I try to
> open, my winGRASS goes "bananas".
Hope you get some whipped cream with that ;-)
> Just to sum what I have done
> 1- Import a xyz ASCII file that is a float with a range of [166297.00
> - 20855944.0] (not all values are used) and Rows: 4655
> ;Columns: 4520 .
About 20,000,000 cells. That should be OK.
Do you know how many different values are actually in the data?
> 2- I did r.mapcalc int() to this file that gets the range of [166297
> 20855944].
> QUESTION: can I apply int to a FLoat with values as big as this?
An integer raster is represented by 32 bit signed integer values i.e.
from (about) -2 billion to +2 billion. So you're OK here.
> 3- I did r.mode base=int_base coverage= 11073_B at PERMANENT (it's a
> high-resolution image) output=output1
> Ok it runs (it takes some time as expected)
> Thern if I try to display it freezes... Even If I just try r.info
> <http://r.info> output1 it also freezes.
I'd try two things here. First can you change to a smaller region and
rerun r.mode and try to display the results?
Second: the result of r.mode is a "reclass" of the original values. So I
suppose it has to be recalculated each time you want to display. You can
make that reclass map into a permanent raster by running:
r.mapcalc "output2 = output1"
Then try displaying the output2.
> Any thoughts aboutt this? (Thanks Micha)
> On Tue, Oct 19, 2010 at 2:14 PM, Micha Silver <micha at arava.co.il
> Greetings
> This new topic is related with
> I need to calculate mode for a base map that is composed by
> float values.
> r.mode base=base at PERMANENT cover=11073_B at PERMANENT output=saida
> And I get:
> ERROR: reading r.stats output
> ERROR: No rules specified
> This means that I'm not being able to apply this function just
> because my base map is a Float. Any ideas of how to fix this?
> How about r.mapcalc base_integer=int(base) ?
> The base map should be integer (category ) values, where the mode
> is calculated for all cells with the same cat value, so it indeed
> should be an integer raster.
> Thanks
> Monica
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101019/b8e082bb/attachment.html
