[GRASS-user] Question about r.in.xyz
Franz Schiller
franzschiller1975 at gmail.com
Wed Oct 20 04:18:21 EDT 2010
That was a typo. What I mean is that, when I imported that file it has
applied all those zscale, percent and methods. My question is: does this
"change my data"?
On Tue, Oct 19, 2010 at 7:22 PM, Daniel Victoria
<daniel.victoria at gmail.com>wrote:
> In your r.in.xyz the input file is named filev2 while in the r.info
> command it says input is named saidav2. Is that what you mean by
> different?
> Daniel
> On Tue, Oct 19, 2010 at 6:15 AM, Franz Schiller
> <franzschiller1975 at gmail.com> wrote:
> > Hi Hamish
> >> that's simply a function of what's present in your input data.
> >> for floating point values it will just be the next highest
> >> integer beyond the maximum data value and can be ignored.
> > Uhm but it has to do with the "number of categores"? It's used for
> Histogram
> > only?
> >> see also the output of r.univar and the display histogram tool.
> > Ok r.univar is ok (I guess).
> >> > - and in the r.info v2 I get a command slightly different from
> >> > the one I typed:
> >> > r.in.xyz input="C:\Test_areas\graphbased\saidav2" \
> >> > output="v2 at PERMANENT" method="mean" type="FCELL" fs=" " \
> >> > x=1 y=2 z=3 zscale=1.0 percent=100
> >> > Why?
> > But it didn't change my dataset right?
> > Franz
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101020/2d86d2b9/attachment.html
