[GRASS-user] error compiling grass65svn and addons for grass64
Laura Poggio
laura.poggio at gmail.com
Thu Oct 21 02:44:42 EDT 2010
grass-devel is installed. Below the error message is I try to use make with
MODULE_TOPDIR=/path/to/grass instead of g.extension.
thank you very much!
Laura
gcc
-I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include
-O2 -I/usr/include/gdal/ -DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/io.o -c
io.c
io.c:1:27: error: grass/glocale.h: No such file or
directory
In file included from
io.c:2:
global.h:5:23: error: grass/gis.h: No such file or
directory
global.h:6:24: error: grass/Vect.h: No such file or
directory
global.h:7:24: error: grass/dbmi.h: No such file or
directory
io.c:2:
global.h:80: error: expected ‘)’ before ‘*’
token
global.h:81: error: expected ‘)’ before ‘*’
token
io.c:2:
global.h:93: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
token
global.h:94: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
token
io.c: In function
‘open_raster’:
io.c:8: error: storage size of ‘cellhd’ isn’t
known
io.c:10: warning: assignment makes pointer from integer without a
cast
io.c:16: error: ‘CELL_TYPE’ undeclared (first use in this
function)
io.c:16: error: (Each undeclared identifier is reported only
once
io.c:16: error: for each function it appears
in.)
io.c:26: error: invalid use of undefined type ‘struct
Cell_head’
Cell_head’
io.c: In function
‘create_base_maps’:
io.c:37: error: ‘CELL’ undeclared (first use in this
function)
io.c:37: error: ‘r_dirs’ undeclared (first use in this
function)
io.c:37: error: ‘r_streams’ undeclared (first use in this
function)
io.c:38: error: ‘DCELL’ undeclared (first use in this
function)
io.c:38: error: ‘r_accum’ undeclared (first use in this
function)
io.c:47: error: ‘dirs’ undeclared (first use in this
function)
io.c:47: error: expected expression before ‘)’
token
io.c:48: error: ‘streams’ undeclared (first use in this
function)
io.c:48: error: expected expression before ‘)’
token
io.c:50: error: ‘accum’ undeclared (first use in this
function)
io.c:50: error: expected expression before ‘)’
token
io.c:52: error: expected expression before ‘)’
token
io.c:53: error: expected expression before ‘)’
token
io.c:55: error: expected expression before ‘)’
token
io.c:73: error: expected expression before ‘)’ token
io.c: In function ‘stream_number’:
io.c:120: error: ‘CELL’ undeclared (first use in this function)
io.c:120: error: expected ‘;’ before ‘c_min’
io.c:121: error: storage size of ‘stream_range’ isn’t known
io.c:124: warning: assignment makes pointer from integer without a cast
io.c:126: error: ‘c_min’ undeclared (first use in this function)
io.c:126: error: ‘c_max’ undeclared (first use in this function)
io.c: In function ‘write_maps’:
io.c:136: error: ‘CELL’ undeclared (first use in this function)
io.c:136: error: ‘strahler_buf’ undeclared (first use in this function)
io.c:136: error: ‘shreeve_buf’ undeclared (first use in this function)
io.c:136: error: ‘hack_buf’ undeclared (first use in this function)
io.c:136: error: ‘horton_buf’ undeclared (first use in this function)
io.c:136: error: ‘topo_buf’ undeclared (first use in this function)
io.c:138: error: storage size of ‘history’ isn’t known
io.c:142: error: ‘CELL_TYPE’ undeclared (first use in this function)
io.c:190: error: ‘streams’ undeclared (first use in this function)
io.c: In function ‘create_table’:
io.c:285: error: ‘dbConnection’ undeclared (first use in this function)
io.c:285: error: expected ‘;’ before ‘conn’
io.c:286: error: ‘dbDriver’ undeclared (first use in this function)
io.c:286: error: ‘driver’ undeclared (first use in this function)
io.c:287: error: ‘dbHandle’ undeclared (first use in this function)
io.c:287: error: expected ‘;’ before ‘handle’
io.c:288: error: ‘dbString’ undeclared (first use in this function)
io.c:288: error: expected ‘;’ before ‘table_name’
io.c:334: error: ‘db_sql’ undeclared (first use in this function)
io.c:335: error: ‘val_string’ undeclared (first use in this function)
io.c:336: error: ‘table_name’ undeclared (first use in this function)
io.c:337: error: ‘handle’ undeclared (first use in this function)
io.c:341: error: ‘conn’ undeclared (first use in this function)
io.c:383: error: ‘DB_OK’ undeclared (first use in this function)
io.c:393: error: ‘DB_PRIV_SELECT’ undeclared (first use in this function)
io.c:393: error: ‘DB_GROUP’ undeclared (first use in this function)
io.c:393: error: ‘DB_PUBLIC’ undeclared (first use in this function)
make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
On 20 October 2010 16:45, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello,
> if SUSE provides separate -dev packages, install grass-dev package.
> Then You have to run Your make commands with
> MODULE_TOPDIR=/path/to/grass.
> See this issue for details: http://trac.osgeo.org/grass/ticket/620
> Still error You had when compiling 6.5 from source must be a different
> one, as provided error message makes sense only to addons and not
> compilation of whole GRASS.
> Maris.
> 2010/10/20, Laura Poggio <laura.poggio at gmail.com>:
> > Yes I have gcc, g++, make.
> > The full error message for one extension is pasted below (for one
> extension
> > as example).
> > Thank you very much
> > Laura
> > Checked out revision 43978.
> > Compiling <r.stream.basins>...
> > In file included from catchment.c:1:
> > global.h:5:23: error: grass/gis.h: No such file or directory
> > directory
> > global.h:7:27: error: grass/glocale.h: No such file or
> > directory
> > global.h:64: error: expected ‘=’, ‘,’, ‘;’,
> > ‘asm’ or ‘__attribute__’ before ‘*’ token
> > catchment.c: In function ‘find_outlets’:
> > catchment.c:29: warning: cast to pointer from integer of
> > different size
> > catchment.c:36: error: ‘streams’ undeclared (first use
> > in this function)
> > catchment.c:36: error: (Each undeclared identifier is
> > reported only once
> > catchment.c:36: error: for each function it appears in.)
> > catchment.c:45: warning: cast to pointer from integer of
> > different size
> > catchment.c:48: error: ‘dirs’ undeclared (first use in
> > this function)
> > catchment.c: In function ‘reset_catchments’:
> > catchment.c:115: error: ‘streams’ undeclared (first use
> > in this function)
> > catchment.c: In function ‘fill_catchments’:
> > catchment.c:147: error: ‘streams’ undeclared (first use
> > in this function)
> > catchment.c:159: error: ‘dirs’ undeclared (first use in
> > this function)
> > make: *** [OBJ.x86_64-unknown-linux-gnu/catchment.o] Error 1
> > ERROR: Compilation failed, sorry. Please check above error messages.
> > test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
> > gcc
> > -o OBJ.x86_64-unknown-linux-gnu/catchment.o -c catchment.c
> > (Wed Oct 20 11:56:21 2010) Command finished (6
> > sec)
> > On 20 October 2010 14:38, <razmjooeis at faunalia.co.uk> wrote:
> >> Have you got the following packges installed?
> >> gcc
> >> g++
> >> make
> >> Cheers
> >> Sab
> >> > Hello,
> >> > You have to provide whole error message. Without exact error text,
> >> > it's impossible to tell what kind of problem You have.
> >> > WBR,
> >> > Maris.
> >> >> Dear all,
> >> >> I installed grass6.4 on a machine with Suse11.2 64 bit from the
> >> >> official
> >> >> repository. Then I tried to install some addons with g.extension and
> >> >> using
> >> >> the usual configure/make/make install.
> >> >> In both cases I get the following error:
> >> >> make: *** [OBJ.x86_64-unknown-linux-gnu/[...]] Error 1
> >> >> I also tried to compile grass65 from svn and I am getting the same
> >> >> error.
> >> >> Please let me know and I can provide more details. Sorry but I do not
> >> >> know
> >> >> what would be useful for better understanding the problem.
> >> >> Thank you very much in advance
> >> >> Laura
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/121999a6/attachment.html
