[GRASS-user] error compiling grass65svn and addons for grass64
Maris Nartiss
maris.gis at gmail.com
Thu Oct 21 03:53:40 EDT 2010
Hello,
You need to edit /path/to/grass/include/Make/Platform.make file (may
need a root for GRASS installed from packages) and change line
"GRASS_HOME" to point to /path/to/grass. Look around that file and
check that other paths also point to existing files and not some
/usr/src/packages/BUILD nonsense.
If You plan to use custom modules (add-ons etc.) I strongly suggest to
compile GRASS from source. You can run GRASS directly from source
directory (no make install required) and easy update it via "svn up"
to get latest fixes. Easy compilation of addons might be fixed at
6.4.1 time, still it's not today.
Good luck,
Maris.
2010/10/21, Laura Poggio <laura.poggio at gmail.com>:
> grass-devel is installed. Below the error message is I try to use make with
> MODULE_TOPDIR=/path/to/grass instead of g.extension.
> thank you very much!
> Laura
> gcc
> -I/usr/src/packages/BUILD/grass-6.4.0/dist.x86_64-unknown-linux-gnu/include
> -O2 -I/usr/include/gdal/ -DPACKAGE=\""grassmods"\"
> -o OBJ.x86_64-unknown-linux-gnu/io.o -c
> io.c
> io.c:1:27: error: grass/glocale.h: No such file or
> directory
> In file included from
> io.c:2:
> global.h:5:23: error: grass/gis.h: No such file or
> directory
> global.h:6:24: error: grass/Vect.h: No such file or
> directory
> global.h:7:24: error: grass/dbmi.h: No such file or
> directory
> io.c:2:
> global.h:80: error: expected ‘)’ before ‘*’
> token
> global.h:81: error: expected ‘)’ before ‘*’
> token
> io.c:2:
> global.h:93: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
> token
> global.h:94: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
> token
> io.c: In function
> ‘open_raster’:
> io.c:8: error: storage size of ‘cellhd’ isn’t
> known
> io.c:10: warning: assignment makes pointer from integer without a
> cast
> io.c:16: error: ‘CELL_TYPE’ undeclared (first use in this
> function)
> io.c:16: error: (Each undeclared identifier is reported only
> once
> io.c:16: error: for each function it appears
> in.)
> io.c:26: error: invalid use of undefined type ‘struct
> Cell_head’
> Cell_head’
> io.c: In function
> ‘create_base_maps’:
> io.c:37: error: ‘CELL’ undeclared (first use in this
> function)
> io.c:37: error: ‘r_dirs’ undeclared (first use in this
> function)
> io.c:37: error: ‘r_streams’ undeclared (first use in this
> function)
> io.c:38: error: ‘DCELL’ undeclared (first use in this
> function)
> io.c:38: error: ‘r_accum’ undeclared (first use in this
> function)
> io.c:47: error: ‘dirs’ undeclared (first use in this
> function)
> io.c:47: error: expected expression before ‘)’
> token
> io.c:48: error: ‘streams’ undeclared (first use in this
> function)
> io.c:48: error: expected expression before ‘)’
> token
> io.c:50: error: ‘accum’ undeclared (first use in this
> function)
> io.c:50: error: expected expression before ‘)’
> token
> io.c:52: error: expected expression before ‘)’
> token
> io.c:53: error: expected expression before ‘)’
> token
> io.c:55: error: expected expression before ‘)’
> token
> io.c:73: error: expected expression before ‘)’ token
> io.c: In function ‘stream_number’:
> io.c:120: error: ‘CELL’ undeclared (first use in this function)
> io.c:120: error: expected ‘;’ before ‘c_min’
> io.c:121: error: storage size of ‘stream_range’ isn’t known
> io.c:124: warning: assignment makes pointer from integer without a cast
> io.c:126: error: ‘c_min’ undeclared (first use in this function)
> io.c:126: error: ‘c_max’ undeclared (first use in this function)
> io.c: In function ‘write_maps’:
> io.c:136: error: ‘CELL’ undeclared (first use in this function)
> io.c:136: error: ‘strahler_buf’ undeclared (first use in this function)
> io.c:136: error: ‘shreeve_buf’ undeclared (first use in this function)
> io.c:136: error: ‘hack_buf’ undeclared (first use in this function)
> io.c:136: error: ‘horton_buf’ undeclared (first use in this function)
> io.c:136: error: ‘topo_buf’ undeclared (first use in this function)
> io.c:138: error: storage size of ‘history’ isn’t known
> io.c:142: error: ‘CELL_TYPE’ undeclared (first use in this function)
> io.c:190: error: ‘streams’ undeclared (first use in this function)
> io.c: In function ‘create_table’:
> io.c:285: error: ‘dbConnection’ undeclared (first use in this function)
> io.c:285: error: expected ‘;’ before ‘conn’
> io.c:286: error: ‘dbDriver’ undeclared (first use in this function)
> io.c:286: error: ‘driver’ undeclared (first use in this function)
> io.c:287: error: ‘dbHandle’ undeclared (first use in this function)
> io.c:287: error: expected ‘;’ before ‘handle’
> io.c:288: error: ‘dbString’ undeclared (first use in this function)
> io.c:288: error: expected ‘;’ before ‘table_name’
> io.c:334: error: ‘db_sql’ undeclared (first use in this function)
> io.c:335: error: ‘val_string’ undeclared (first use in this function)
> io.c:336: error: ‘table_name’ undeclared (first use in this function)
> io.c:337: error: ‘handle’ undeclared (first use in this function)
> io.c:341: error: ‘conn’ undeclared (first use in this function)
> io.c:383: error: ‘DB_OK’ undeclared (first use in this function)
> io.c:393: error: ‘DB_PRIV_SELECT’ undeclared (first use in this function)
> io.c:393: error: ‘DB_GROUP’ undeclared (first use in this function)
> io.c:393: error: ‘DB_PUBLIC’ undeclared (first use in this function)
> make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
> On 20 October 2010 16:45, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Hello,
>> if SUSE provides separate -dev packages, install grass-dev package.
>> Then You have to run Your make commands with
>> MODULE_TOPDIR=/path/to/grass.
>> See this issue for details: http://trac.osgeo.org/grass/ticket/620
>> Still error You had when compiling 6.5 from source must be a different
>> one, as provided error message makes sense only to addons and not
>> compilation of whole GRASS.
>> Maris.
>> 2010/10/20, Laura Poggio <laura.poggio at gmail.com>:
>> > Yes I have gcc, g++, make.
>> > The full error message for one extension is pasted below (for one
>> extension
>> > as example).
>> > Thank you very much
>> > Laura
>> > Checked out revision 43978.
>> > Compiling <r.stream.basins>...
>> > In file included from catchment.c:1:
>> > global.h:5:23: error: grass/gis.h: No such file or directory
>> > directory
>> > global.h:7:27: error: grass/glocale.h: No such file or
>> > directory
>> > global.h:64: error: expected ‘=’, ‘,’, ‘;’,
>> > ‘asm’ or ‘__attribute__’ before ‘*’ token
>> > catchment.c: In function ‘find_outlets’:
>> > catchment.c:29: warning: cast to pointer from integer of
>> > different size
>> > catchment.c:36: error: ‘streams’ undeclared (first use
>> > in this function)
>> > catchment.c:36: error: (Each undeclared identifier is
>> > reported only once
>> > catchment.c:36: error: for each function it appears in.)
>> > catchment.c:45: warning: cast to pointer from integer of
>> > different size
>> > catchment.c:48: error: ‘dirs’ undeclared (first use in
>> > this function)
>> > catchment.c: In function ‘reset_catchments’:
>> > catchment.c:115: error: ‘streams’ undeclared (first use
>> > in this function)
>> > catchment.c: In function ‘fill_catchments’:
>> > catchment.c:147: error: ‘streams’ undeclared (first use
>> > in this function)
>> > catchment.c:159: error: ‘dirs’ undeclared (first use in
>> > this function)
>> > make: *** [OBJ.x86_64-unknown-linux-gnu/catchment.o] Error 1
>> > ERROR: Compilation failed, sorry. Please check above error messages.
>> > test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
>> > gcc
>> > -o OBJ.x86_64-unknown-linux-gnu/catchment.o -c catchment.c
>> > (Wed Oct 20 11:56:21 2010) Command finished (6
>> > sec)
>> > On 20 October 2010 14:38, <razmjooeis at faunalia.co.uk> wrote:
>> >> Have you got the following packges installed?
>> >> gcc
>> >> g++
>> >> make
>> >> Cheers
>> >> Sab
>> >> > Hello,
>> >> > You have to provide whole error message. Without exact error text,
>> >> > it's impossible to tell what kind of problem You have.
>> >> > WBR,
>> >> > Maris.
>> >> >> Dear all,
>> >> >> I installed grass6.4 on a machine with Suse11.2 64 bit from the
>> >> >> official
>> >> >> repository. Then I tried to install some addons with g.extension
>> >> >> and
>> >> >> using
>> >> >> the usual configure/make/make install.
>> >> >> In both cases I get the following error:
>> >> >> make: *** [OBJ.x86_64-unknown-linux-gnu/[...]] Error 1
>> >> >> I also tried to compile grass65 from svn and I am getting the same
>> >> >> error.
>> >> >> Please let me know and I can provide more details. Sorry but I do
>> >> >> not
>> >> >> know
>> >> >> what would be useful for better understanding the problem.
>> >> >> Thank you very much in advance
>> >> >> Laura
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
