[GRASS-user] g.extension (e.g. to install i.landsat.toar)
Nick Jachowski
njachowski at gmail.com
Fri Oct 22 10:20:08 EDT 2010
I'm trying to get the grass add-on i.landsat.toar to work using g.extension,
and I've had many problems. I had been trying it on opensuse 11.3 and I
installed various versions of grass from source, but they all had problems
and did not work. I've almost given up, and now I am running grass on
poseidon linux (ubuntu base) which came preinstalled with Grass 6.4ORC5. My
question is: what is the easiest, most pain-free way to get g.extension to
work? What linux flavour should I be using (and is 32-bit or 64-bit
better)? Which GRASS version number? Do I need to install from source?
If I can't get g.extension to work properly are there any workarounds such
as running it as bash script?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/g-extension-e-g-to-install-i-landsat-toar-tp5662708p5662708.html
Sent from the Grass - Users mailing list archive at Nabble.com.
