[GRASS-user] Re: Change database type (Micha Silver)
Pablo Carreira pablotcarreira at hotmail.com
Fri Oct 22 12:20:55 EDT 2010
Micha, Richard.
Thank you very much for the help.
Pablo Torres Carreira
> Date: Fri, 22 Oct 2010 08:34:50 +1100
> From: rchirgwin at ozemail.com.au
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] Re: Change database type (Micha Silver)
> On 22/10/10 8:12 AM, grass-user-request at lists.osgeo.org wrote:
> > Send grass-user mailing list submissions to
> > To subscribe or unsubscribe via the World Wide Web, visit
> > 	http://lists.osgeo.org/mailman/listinfo/grass-user
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> > 	grass-user-owner at lists.osgeo.org
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of grass-user digest..."
> > Today's Topics:
> >     1. Change database type (Pablo Carreira)
> >     2. v.in.ogr and g.region trouble coordenate (Ricardo Rodr?guez)
> >     3. Re: Change database type (Micha Silver)
> >     4. Re: v.in.ogr and g.region trouble coordenate (Micha Silver)
> >     5. nviz_cmd problem winGrass6.5 - 7.0 (M.Onur Kurum)
> > Message: 1
> > Date: Thu, 21 Oct 2010 15:23:15 -0200
> > From: Pablo Carreira<pablotcarreira at hotmail.com>
> > Subject: [GRASS-user] Change database type
> > To:<grass-user at lists.osgeo.org>
> > Message-ID:<SNT114-W15AB33CF89A9A96DFBD9B5D65D0 at phx.gbl>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Hi,
> > I have many vectors with tables and now I want to change my database from sqlite to pgsql.I ran db.connect. And now I need to copy all the tables from sqlite to pgsql.Is there an easy way to do that?
> > Thanks.
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/4ad2cda2/attachment-0001.html
> > Message: 2
> > Date: Thu, 21 Oct 2010 15:19:17 -0500
> > From: Ricardo Rodr?guez<ricardorodot02 at gmail.com>
> > Subject: [GRASS-user] v.in.ogr and g.region trouble coordenate
> > Message-ID:
> > 	<AANLkTi=sUMPrB-4VxP=S8xjfT=Oj1PGzuaHe03EXgCfG at mail.gmail.com>
> > hello.
> >   how to make g.region and v.in.ogr use the same projection that an incoming
> > file. since at run-d g.region v.in.ogr and maintaining the coordinates but
> > not the coordinate system, given the same coordinate system of the lease,
> > what should I do to keep your incoming file coordinate system .
> > thanks for your help and attention
> > Ricardo Rodríguez
> > Univalle
> > URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101021/3ae60005/attachment-0001.html
> > Message: 3
> > Date: Thu, 21 Oct 2010 22:38:01 +0200
> > From: Micha Silver<micha at arava.co.il>
> > Subject: Re: [GRASS-user] Change database type
> > To: Pablo Carreira<pablotcarreira at hotmail.com>
> > Cc: grass-user at lists.osgeo.org
> > Message-ID:<4CC0A4A9.2 at arava.co.il>
> > On 10/21/2010 07:23 PM, Pablo Carreira wrote:
> >> Hi,
> >> pgsql.
> > Once you've set the database connection params, then g.copy will create
> > a new vector with the attributes pushed into the new database. So you
> > could loop thru all vectors something like:
> > for v in `g.mlist vect`; do
> >       g.rename vect=$v,$v_sqlite  # rename to temporary name
> >        g.copy vect=$v_sqlite,$v        # copy back to original name, but
> > pgsql tables will be created
> > done
> > If everything looks good, then you can remove all the vectors *_sqlite:
> > g.remove vect=`g.mlist vect sep=, pat="*_sqlite"`
> >> Thanks.
> >> This mail was received via Mail-SeCure System.
> >> _______________________________________________
> Alternatively, if you want to keep the two separate, create a new
> mapset, set the database connection in the new mapset, and copy the maps
> from old mapset to new.
> Hence, in the new mapset:
> for i in `g.list vect mapset=<oldmapset>`; do
> g.copy vect=$i"@<oldmapset",$i
> done
> Often if I am going to be working away from the MySQL server, I do this
> to create a copy with a dbf connection.
> Cheers,
> Richard
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101022/acb8f1cf/attachment.html
