[GRASS-user] g.extension (e.g. to install i.landsat.toar)
Nick Jachowski
njachowski at gmail.com
Sun Oct 24 09:56:48 EDT 2010
Thanks for your help Markus.
I am now trying to use g.extension with GRASS 6.5.svn and GRASS 7.0.svn on
Ubuntu 10.10, however when I start either versions of GRASS and try to open
a new location (using the wxPython gui) I get the following error:
> g.proj: error while loading shared libraries: libgdal1.5.0.so.1: cannot
open shared object file: No such file or directory
I searched for libgdal and found that I have libgdal1.6.0.so.1 at
./usr/lib/libgdal1.6.0.so.1
I don't care whether or not I get GRASS working on this OS or even what
version of GRASS I get to work. I am just interested in the easiest way to
use g.extension to be able to use the i.landsat.toar addon. Is there a
flavour of linux that is particularly easy to use when it comes to GRASS?
And would you recommend GRASS 6.4.0, 6.5, or 7.0 to get g.extension to
work?
Any help is appreciated, thanks!
Nick
On Fri, Oct 22, 2010 at 12:09 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Oct 22, 2010 at 4:20 PM, Nick Jachowski <njachowski at gmail.com>
> wrote:
> > I'm trying to get the grass add-on i.landsat.toar to work using
> g.extension,
> > and I've had many problems. I had been trying it on opensuse 11.3 and I
> > installed various versions of grass from source, but they all had
> problems
> > and did not work.
> You mean that GRASS (which version) did not work or that g.extension within
> it failed? Note that there is a known bug for g.extension usage in the
> Makefile
> system due to a wrong path which also manifests in OpenSuse.
> > I've almost given up, and now I am running grass on
> > poseidon linux (ubuntu base) which came preinstalled with Grass 6.4ORC5.
> (that's fairly old...)
> > My question is: what is the easiest, most pain-free way to get
> g.extension to
> > work? What linux flavour should I be using (and is 32-bit or 64-bit
> > better)? Which GRASS version number? Do I need to install from source?
> It would be needed to fix for many platforms this bug:
> http://trac.osgeo.org/grass/ticket/620
> In general, please use 6.4.0 (or 6.4.svn).
> > If I can't get g.extension to work properly are there any workarounds
> such
> > as running it as bash script?
> It needs to be compiled. You can manually fix the path in
> include/Make/Platform.make (see above ticket), then g.extension
> should work. Yesterday I made an attempt to also fix the
> system wide installation (in GRASS 6.5) which might be
> backported.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101024/155ca540/attachment.html
